Talal
    4
Everything posted by Talal
  1. Got it thank you - I will try changing this setting on all of our computers and will report if issue persists. Thank again Tolu!
  2. Oh my bad, no it is online only. Screenshot attached.
  3. 1) MacOS 2) Dropbox v166.4.2920 3) Dropbox location on machine is under user>company's dropbox. 4) I dont see a "Sync" tab under Dropbox Preferences. See attached. Thanks,
  4. Hello, Thanks for landing here - We are several users working on a project via project sharing - all running on DropBox Business. Ever since we all upgraded to VW 2023, we have been facing constant issues with project sharing to the point that we are considering abandoning it and going back to each breaking up projects into separate files. Issue is very simple and cannot seem to fix it. Basically, if one person saves and commits and the project file is showing latest greatest updates - at some point, when another user refreshes, they get an error saying 'the project file associated with this working file could not be found'. Although it would be in the same location, so sure, we would hit 'Manually locate the Project File' then select it. At that point, nothing happens. The error keeps popping up after 3/4 times of locating the project file on the dropbox server, so user is forced to 'work in offline mode' to attempt to salvage the file. The only solution is to save the file back to a regular VWX, consolidate all the work from the different users into 1 file and then re convert to a project sharing file, and have everyone set up their working files again. Very inconvenient and time consuming - not worth doing project sharing at that point. I should mention that the save and commit then refresh on a different station works a few times before ultimately failing for everyone Anybody been facing similar issues? Any ideas on what might be causing this? We were not facing this issue on VW 22. Thank you,
