zackimcdlighting
    2
Everything posted by zackimcdlighting
  1. I am experiencing unexpected reflection rendering. I have a rectangular extrude that is drawn in front of another rectangular extrude that has a glass texture applied to it. In Shaded rendering, normal perspective, depending on the angle I view it at, faces of the rectangle appear and disappear. Why is this happening and is there a way to fix this? VWX 2024 Update 3.1 (Build 739493)
  2. I'm looking for a way to globally set values of multiple lighting devices' Voltage, Time, Cost, and Weight parameters. I know I can do this after I insert the Lighting Devices but I'd like to have their values already set before insertion. I know that I could change the Weight in Lighting Symbol Maintenance but the other parameters (Voltage, Time Cost) don't appear in this window. I was able to add these fields (Voltage, Time, Cost) to the Light Info Record allowing me to set these field values before insertion. Even after I added these fields to the Light Info Record, they don't show up in the Lighting Symbol Maintenance window. Why is this? Can they be added to this window? I want to be able to bulk edit the Voltage / Time / Cost of multiple lights at once. Is there a solution for this? Thank you, Zack Vectorworks Spotlight 2023 SP7 (Build 719048) (64-Bit) MacOS Sonoma 14.1 (23B74)
