Hi, I'm in the initial stages of learning about the plant tool and am finding many frustrations. One is that if I go to the Edit Plant Style window and make any changes at all... in fact even if I DON'T make any changes but just click OK... it automatically opens the Vectorworks Plant Database. This also happens if I try to open the Plant Catalogue in the same window. Is there a way of preventing this happening?
Problem no 2 occurs when using the polyvertex mode for inserting plants. I have set the Polygon Display to draw lines between the grouped plants, but no lines show up. I can't alter it in the object info palette as this field, along with many others, is greyed out. But even when I go into plant style to do it there, this particular change isn't saved. Is there a setting that I need to change?
Thanks in advance for your help!
