tomcee
    3
Reputation
1 Neutral
Personal Information
  • Location
    Australia
  1. Has anyone successfully got this to work as an option within a wrapper? I can get it to work unwrapped but it breaks once wrapped. Simple example attached. For background: I have a script that, once configured, is to be run multiple times to build geometry on a set of control lines of the same length. I'd like the users to be able to simply chose to ungroup/detach the geometry from Marionette once they are ready to build on all the lines. Detach From Script Example.vwx
  2. Thanks Pat. Any idea why it doesn't work in a wrapper? Unfortunately the text box doesn't give me the alignment I need however I did find a work around: by grouping the "Convert To Poly Group" output it now wraps and works as expected. Logo In Marionette v03.vwx
  3. Hi Attached is a script to recreate our company name and logo that is font size controllable and font independent. End goal is this to be an object node. The script works until I wrap the script then only the converted text objects are output and not the geometry. I think it has something to do with the "Convert To Poly Group" node as when I exclude this from the script the text and geometry work in the wrapper. Anyone have an idea what might be going on? Simplified version of script attached. Thanks! Logo In Marionette v02.vwx
