Kurt Lesh
    9
Everything posted by Kurt Lesh
  1. Is there a way to create hyperlinks for the sheet list? Trying to make it easier to navigate larger PDFs..
  2. Yup that did the trick. With the change in v2024 in how the rack tools work, I have to toggle between Front & Top views extremely frequently now. My 3D mouse only lets me select "Top" for presets...
  3. Recording 2023-10-26 092231.mp4 Screen recording and design file attached. I've tired this on another computer as well as same results. 10397 Hope International STRAY Drawings.vwx
  4. Anyone else experiencing issues wit the "Connect" cool in ConnectCAD in v2024? I will be working on a schematic, drawing away and then the Connect tool that ive been using all day will just stop working and I wont be able to draw connections. I have had this with multiple files. It will eventually start working again, but I cant nail down anything to cause it.
  5. Ok so see whats happening - I am trying to link the description to the worksheet of cables, but because the description is different on each end, it doesn't know what to pull. Is there a way to do a destination device description record? Or even a way I can just type something in that column?
  6. 2022 SP5 - Build664120 I tried using the "Device" record as well, with no luck. Screenshots attached...
  7. Trying to link the device description from my schematic layer with a column on a worksheet but for the life of me cannot get it to work. Im using the "Dev_Rec", "description info which is the same record the schematic layer is pulling the info from, but it doesn't populate anything. All other info in my worksheet is linking fine, so I expect my criteria is fine... Am I missing something? Or is there a better way to do this?
