I have all classes set to visible, and there were titleblocks on my sheets an hour ago, but they have all vanished and I cannot add any more from the dims menu!
When I try and add a new one, a dotted line appears but I cannot insert a titleblock.
Wasting so. much. time.
I am importing a 1:200 site map into vectorworks, and when I zoom in on it the line quality is very fuzzy. However, when I go to PDF crop it is very sharp when I zoom in - but I need all of it to be sharp!
Hi there
I am working on a plan at 1:200 scale and I want to draw out the planting areas at 1:50.
I have set up data tags with a font size of 12 and put a sheet together with a VP scaled at 1:50.
The writing is enormous! I have checked the autoscale in the advanced viewport options - how can I get the text in the data tags back to size?
Thanks
Ah yes -Tom - the tutorial says data tags but she created a key on a separate layer which uses plant tags and pulls up the size data for reference when you are drawing. It comes up in the dialogue box anyway so maybe not essential ....
Perfect - thank you! I was just working through the association / style
I have had another problem with the plant (not data) tags though.
I am following a tutorial where there is a separate 'Plant List sheet' where you insert all your plants you plant to use, then tag them with a custom plant tag:
Name - Spread - Height.
When I go to do this the OIP has tags greyed out so I am struggling to follow the tutorial..
Hi there
I am planning a planting scheme on VW for the first time and have set up some plants in 'exported plants'
I have disabled the plant label as I find it cumbersome and want to label the plan in the design layer using data tags.
When I add a data tag, there is no text - all class visibilities are on..... help!
