There's a much simpler solution. Go to the Navigation palette and select the Section Viewport that you want to display section markers for in your 2D layer. At the bottom of the Object Info palette for the Section Viewport open "Section Line Instances". Select the Viewport tab and check the viewports that you want to display Section Line Markers in. Your Section Line Markers should now appear in your desired Viewports.
