Andreas
16 -
Reputation
0 NeutralPersonal Information
Location
Belgium
This works -> vs.UpdateStyledObjects('StyleName')
Thanks, Neither vs.ResetObject(h) works.
Thanks Spettitt But it doesn't work
Dear VW forum I'm looking for a function who can update/redraw/regenerate all the plug-in object in the model. I'll try to explain better: I have several doors-windows generated from plug-in object, I modify a component in the wall (thickness for example) where the plug-in objects are inserted and, I see the changes of the component thickness but to obtain a correct update of the plug in object i need to move-it and then the plug-in objects are well redraw. here an example: I change the insulation thickness in this wall. Then I see this: before moving after.. The functions vs.ReDraw() and vs.ReDrawAll() don't works..
I have the same issues.
vs.AddSymToWallEdge(inWall, offset, height, flip, right, symName, mode) I suppose..
Dear Vectorworks forum I'm trying to create a script to insert a symbol in a wall. After both object have been selected, then I'm trying using vs.CreateDuplicateObject() or vs.SetParent() to fit the symbol in the wall but, without result. Thanks in advance.
Thank you very much!
Dear vectorworks forum How do I get the handle of a wall from a selected plug in object? (The plug in object (door or window) is into the wall ) Thanks
Dear vw forum expert. Today we had a boring problem using vw2024. Lines of doors and windows becomes withes without reason after refreshing a project file. Here an image to prove this issues. We can't understand why this happen. Thanks in advance.
Thanks for yours replies @MullinRJ and @Marissa Farrell I changed function and using " vs.Set3DRot( handle , angX, angY, angZ, oX, oY, oZ ) " works well for all objects types. Thanks also for this solution, I'll keep " vs.HRotate() " in mind 🙂
Also with a marionette script doesn't work.. Here attached fileVS-SetAngle issue.vwx
Dear VectorWorks forum: I need to write a script in order to change the rotation angle of some object with a specified parameter. But I have an issue using this python function: - vs.SetAngle(h, value) - cause nothing change after the script run. vs.HAngle(h) works perfectly, I can get the rotation parameter. I think I'm writing something wrong in the parameters method. Here the script: def SetRot(h): rotValue = vs.HAngle(h) vs.AlrtDialog(rotValue) vs.SetAngle(h, 75.0 ) vs.SetDSelect(h) vs.SelectObj("INSYMBOL & INVIEWPORT & ((PON='Data Tag') & (PST=''))") vs.ForEachObjectInLayer(SetRot, 2, 0, 2) Thanks
Horizontal Section Viewport lines thickness
Andreas replied to Andreas's question in Wishlist - Feature and Content Requests
Dears @MatPanzer and @Line-weight Thanks for yours answers. The solution to this issue is check "Add profile line" and the HSV show correctly the boundaries lines of the wall . "Display extents below cut plane" is why a HSV is needed , cause a classic Viewport don't show correctly the projected object (and also the cut objects aren't properly displayed sometimes). In any case thanks you very much, I really appreciate yours help. And for the Wishlist, please update the classic Viewport in order to avoid the use of the HSV , if possible, of course. Sincerely -
Thanks @line-weight Here the file ViewPort lines issues.vwx
