kirsten18
    3
Reputation
1 Neutral
Personal Information
  • Location
    United States
  1. @Andy Broomell Ah thank you!! Changing the 'Other Markers' setting worked. My brain is still in weekend mode I guess.
  2. Hi all - I'm trying to edit a Custom Dimension Standard and having a lot of trouble. My angular dimensions are showing super large markers no matter what I change the parameters to. I've attached 2 pictures showing which Dimension Standard I'm working with and what I have the marker settings set to (It's a different dimension style than the other dimensions on the page). I feel like I've tried everything so if someone could help me out it'd be much appreciated. Thanks in advance!!
  3. Hi everyone, I realize I'm a bit late to the conversation but I have realized that this only happens when you print the PDF. If you print straight from Vectorworks, the crop box does not show up. I had 3 pages I wanted to print as a set so I published them to PDF then printed from Adobe Acrobat, and the crop box printed. But when I printed the same document straight from Vectorworks, the crop box did not print. Hope this helps!
