kllovan
    4
Everything posted by kllovan
  1. @Nikolay Zhelyazkov I may have overwrite saved on this file. Let me check and I can send it to you.
  2. @Nikolay Zhelyazkov yes. I tried this first. Unfortunately it still started at -065 no matter how many times I cleared it. Wanted it to start at XXX-001. When I used the Spotlight method, it would give me XXX-001 for the first one and then XXX-2 for the increment. Nothing I could do would match up the correct way. So I copied all after I cleared the numbers, pasted in place in another file. Deleted everything out of my current file. Then numbered cables in the new file. It got everything perfect. Then copied out of the untitled file back into the original file.
  3. It's a pain, but if you copy everything, and paste in place in a new file.....the numbering works once again. Something to consider
  4. @Thomas K. I have this same issue where clearing out the numbers didn't change anything and I need to renumber a couple hundred SDI. Did you ever find the work around where it doesn't start at the last assigned number? Spotlight number doesn't get me with the numbering I need unfortunately.
