284 -
Posts posted by Francois Levy
I see that DEM import hasn't been discussed here in _10 years_
Is it currently possible to import DEM datasets into Vectorworks? I’ve downloaded some LIDAR datasets from a municipality, and it’s showing up as a folder with numerous XML, RDD, and IMG files.
Brilliant! Thanks, Pat!
I'm having a similar issue where the subdivision I have created is not solid, even if I convert to mesh or generic solid. Any suggestions?
Thank you very much Jeff, I appreciate it!
- 1
Hello,
I need a Hatch for a fish-scale shingle and I think the attached PAT file may suit my needs. I think it must be imported into AutoCAD, applied to a poly, and then the file saved as a DWG for me to be able to import it into Vectorworks. Can anyone lend a hand?
Thanks!
François
Hi Jim,
I seem to recall I used to be able to map an image onto a site model—say, an aerial photo or a scanned hand sketch of a proposed landscape plan. I seem to be unable to do that though in 2022—user error no doubt. If I create a texture (even a non-repeating one), that is smaller than the site model, it repeats. Even if I make the texture the same shape and size as the site model's crop (challenging), the texture is applied to each individual face of the TIN. What am I missing?
On 7/27/2017 at 7:56 AM, PVA - Jim said:This is currently possible with a single photo, what problems are you having trying to do it?
If you have multiple photos, they can be assembled into one with a photo editor and then imported as a texture and applied to a site model.
- 1
Matt, I also do not use Create Similar. I do option-drag a lot, though.
In the morning or mid-afternoon if I haven't had my coffee I don't even need the option key; I just drag.
- 1
That's been my exact experience, too. I'd love to file a bug rather than be resigned about it and accept it as a fact of life, but it's not really reproducible, just really annoying.
Thanks Kevin. Since None is my default container class, I don't have it's attributes set to use at creation, unlike almost all my other classes. However, why should that matter? If I have nothing selected, and set my Attributes to class settings, it should not revert to white fill and black line. Not to mention the text issues.
I am embarrassed to say this has been plaguing me for years; there's likely something simple I'm missing. It seems that most of the time by attributes palette reverts to white fill, black line, even if I set it to all attributes by class by default. Why does it revert on its own, and how can I make it stop.
I see analogous behavior with text. For a long while text has been by default right-justified, even if I deliberately set my default to Calibri 8pt left.
Thoughts?
- 1
On 9/15/2019 at 10:15 PM, Peter Neufeld said:
Interactive
Cursor Pre Selection Highlighting Timer: Set to 5 seconds
Nothing more annoying than everything highlighting as you move the mouse across a busy plan.
On 9/16/2019 at 5:33 AM, Christiaan said:Cor that's a long time to wait for pre-selection though
I set mine to about 0.6 seconds; seems to be long enough to avoid everything lighting up like a pinball machine, but not too long to wait if you want the highlighting.
- 2
Thanks, Brian!
I'm very pleased to announce the release of BIM for Design Firm: Data Rich Architecture at Small and Medium Scales. While not a strictly Vectorworks book, obviously our favorite program was an important influence and had a significant impact. After you've had a chance to read it, I'd appreciate your sharing your comments over at its Amazon page. And if anyone from the press would like a review copy, please ping me.
Cheers,
François
- 3
I've tried connecting a Sharp TV (LC-65LE654U) via the HDMI3 port to my 2017 Macbook Pro running Mac OS 10.13.6. The Mac "sees" the TV (lists it by the correct model number in the Displays pane of the System Preferences) but the TV reports "no signal". I've tried both other HDMI ports, turning the TV off and on, still doesn't work. It's not the cable, as a Windows laptop connects to the TV just fine. Any ideas?
I'll be teaching a 2-day hands-on Vectorworks BIM workshop at the AIA offices in Santa Fe, New Mexico, USA, on October 12 and 13:
https://www.eventbrite.com/e/santa-fe-vectorworks-bim-workshop-tickets-50280749074
- 2
That was a great webinar, Jonathan. Thank you as always for sharing your knowledge with the community.
PS I do not have your email address so am using private messaging on the forum. If you prefer email, find me at francois@levykohlhaas.com.
Best,
François -
Hi Nina,
I'm attaching a 2018 VWX file with a typical sheet layer we want to export. Again, we'd prefer for section viewports to export as flattened 2D geometry in model space with annotated, cropped paper-space viewports (like plan viewports do). As you can see, Exporting DWG from Vectorworks and reimporting the DWGs into a blank Vectorworks file imports section viewports as scaled, uncropped symbols.
Sounds like an SSD is a good idea, as well as adding 16 or 32GB to the base 8GB.
We're getting ready for a new iMac purchase. The $200 processor upgrade seems an obvious choice (to a .2GHz quad-core i7 processor, Turbo Boost up to 4.5GHz), and of course we'll beef up the RAM. Is there a functional limit to RAM, or does 64-bit VW use as much RAM as is available? What about a drive upgrade? I don't hear good things about Fusion drives; I think for our purposes a 1TB SSD is adequate storage and real-world performance has always seemed much snappier with SSDs. Anyone have any advice on Fusion drives?
Hi Nina,
Thanks for your response. Are you suggesting that in order to achieve the desired DWG output, my section viewports should be on design layers? I've tested that and it doesn't seem to work. Here's what I did:
—I created a sheet layer with three viewports: a top/plan viewport, a section viewport, and a "back" viewport.
—For the sake of the "back" viewport I created a distinct design layer for a single section. There I created section viewport, populating it with the design layers where the model geometry occurs (source design layers), like an old school layer link. Other than this design layer section viewport, this design layer is empty.
—Back on the sheet layer "back" viewport, I placed all annotations for the section drawing there, in its annotation space. Same for the sheet layer section viewport and sheet player top/plan viewport.
—I exported the sheet layer as a DWG.
Here's what I get:
—When importing the DWG back into Vectorworks as a test, both sections come in pretty much the same, whether the sheet layer section viewport or the "back" viewport from a design layer viewport.
—The section plane geometry is a scaled block, uncropped.
—Annotations as well as the geometry beyond the section plane are 1:1 objects (hence out of scale) on the sheet layer itself.
This is really not a usable outcome for my DWG recipient, and seems to be different in some respects from what you describe. Do I need to abandon sheet layers altogether to get the workflow I want? I need to figure this out by September 20th or so, and can share files with you offlist.
Thanks!
We are working with another design firm on a project, and eventually need to hand off DWGs that they can use. Internally, we're employing a BIM workflow: 3D model of the project, viewports for plans and section viewports for interiors and sections. Ultimately we want to be able to export drawings (plans, sections, and interiors in sheet-layer viewports populated by design layer geometry) as DWG model-space entities (design layers) that are annotated and cropped on DWG sheet layers (paper space). Unfortunately, when we do a test DWG export of one of our sheet layers and re-import it back into a blank Vectorworks file, we get sheet layer viewports of plans (good), but scaled symbols in lieu of section viewports that are not even properly cropped (not so good). Is it possible to achieve what we want? Is this a matter of settings, or am I asking the impossible?
I'm completing my second book on BIM in the next few days. I would like to include an eye-catching image of a representative, design-oriented architectural project produced with Revit. If you have any colleagues or associates using Revit who would like to share an exemplary project with me for publication, please contact me offlist: francois.levy.architect@gmail.com. I'd prefer a high-resolution rendering or composition of a smaller project, say under 20,000 SF. Thanks! -
Maxon lists these export formats for C4D that Vectorworks can also import:
3D Studio .3ds
DXF
STL
Wavefront .obj
I would guess that STL is polygons/meshes only, so probably not suitable for my purposes. I'll ask for 3DS, DXF, and OBJ and see which is the cleanest import into Vectorworks.
DEM import?
in Site Design
Posted
Jeff, I don't use Rhino, and I'm not going to introduce it into my workflow for one project (I'm an architect, not a land designer; this is a one-off where getting a proper survey is proving difficult). Kevin, yeah, in fact there were Shapefiles I was able to dig up, but unfortunately all contours are 2D and have no Z data.
