gerry_dup1
25 -
Posts posted by gerry_dup1
I have recently upgraded from Apple OS 10.4.11 to OS 10.5 and i am running Vectorworks 10.5 also. Since upgrading i cannot see the details of any of my architectural drawings as there appears to be a hatch on each drawing. The drawing prints ok, but i cannot work on it due to the hatch like background.
This appears to be directly related to Mac OS 10.5. Any suggestions please.
Gerry
Lately my VW has crashed while importing dwg drawings from an Autocad user. On other occassions it has crashed while trying to pring drawings.
Any suggestions on what to do please?
I have a MAC G5 10.3.8 using Vectorworks 10.5 and when i go to plot a drawing on HP 800ps, the drawing crashes.
This has never happened before.
THANKS TRAVIS
GOT IT WORKING
GERRY
I have just installed Mac OS 10.3.5 into my G5 and when i do a duplicate array using option+command+D [alt+apple+D] which always worked since Mini Cad, i loose the Dock and when i repeat the op[eration it comes back?
How do i carry out multiple arrays?
When i click and open a Vectorworks 10.5 drawing it opens as a viewer, which i cannot work on, until i open the VW programme and then click the drawing. Is there a way to open a drawing that automatically allows me to work on it.
Also when i open the VW programme i always get a blank sheet, which ii don't always want. Can i get rid of this or change the format?
Gerry
VW drawing is 744KB.
I have 512MB of memory
When i try to export a VW10.5 drawing in JPEG
format, i get a message stating 'Could not export image due to lack of memory",
Is this the VW memory, which i have tried to increase but cannot, or some other programme's memory?
Gerry
Thanks Katie
I forgot to add that i have a Mac G5, OSX, VW 10.5
Gerry
I have recently started a new drawing, 2-D, and started dimensioning it. The dimensions are invisible?
katie
Thank you and for all your help, i now have the system up and running properly, from your advice.
Gerry
katie
I have gone through all you said again and in "Generic PostScript Printer" i selected HP800ps and then got the paper sizes which were all "enabled"
Gerry
Katie
Nothing appears in the drop down menu when i select "printer model", except that another menu appears below "printer model" called "Generis PostScript Printer"?
Same with "installable options" nothing appears at all?
thanks Gerry
Katie.
Thank you for your response.
I have done what you suggested on a number of occassions and what i get after selecting the 800 is;
Copies/pages
layout
output options
error handling
peper feed
Vectorworks
summary
It is the finishes i need to 'rotate' the dwg,
The drawings come out correct. The best way to explain my predicament is, if i had a 36' wide plotter i would not have a problem as the drawing width of an A1 landscape 33", would be able to plot correctly due to the plotters width.
My plotter is 24" model, so i get a plot 24" wide, thus losing 9" off the longest dimension of the drawing every time no matter what sheet orientation i select.
I always end up with a completed drawing size of 24"x24"
24" plotter and i have the latest driver installed. i will have to fool around with it for awhile then i think i am going to have to get tough with HP and Apple as i am becoming very frustrated.
i originally purchased hp 500 and was told that there was drivers for it to run on OSX, then i had to send the machine back and was forced to buy the 800ps, which i don't really need. So you can see where i am coming from?
No finishing under copies and pages, only 'Vectorworks' and within VW there is no rotate.
Katie
I removed it and reinstalled it as suggested, still the same. Do you know if there is anyway within Vecterworks 10 where i can rotate my drawings?
Kristen
I do not have "finishing" in the print menu so i can't rotate. It is a real problem and i think it has something to do with the driver, as Katie suggested.
Katie
I know it is St. Stephens day but i am bored and decided to try your suggestion. Unfortunetly i get the same result. It all looked good when i customised my sheet as you suggested and even in preview it was correct, but the sheet is still coming out in partial portrait and still giving me a drawing size of 24"x24"
Richard
I think you are right. It appears to me that what is missing is "rotate". When i set my drawing sheet to "one page" in 'set print area' and select A1 in 'page set up' along with "horizontal" , in preview i get a grey outline in portrait with the drawing in landscape, which suggests that the HP Driver sees it in portrait and that
the drawing should be rotated some how, but i cannot locate the check box for rotate.
In preview I see exactly what i would like the printer to print, but for some unknown reason to me, preview will also show 4 sheets, one with the drawing and the other 3 as blank.
My real problem is that i am not fully au fait with the system i have and it is probably a simple solution.
I have new G5 OS 10.2.8, VW 10.5.0 and HP800ps.
When i select ISO A1 34.5"x23.5" sheet size on landscape or portrait, the printer keeps printing and cutting the sheet short at 24"x24' thus losing 33% of the drawing. Can anyone help me sort this out please.
Unable to see the drawing
in Troubleshooting
Posted
Thanks Peter, i feel your right and this is a bummer that i dont need right now!
