D Wood
541 -
Posts posted by D Wood
Jeffrey
I have refreshed my Browser as suggested, and had to Log-in again of course.
If changes are planned for the Board, could someone please take a look at why I have to Log-in twice before the Board accepts it? It was the same under the Tech Board setup as well.
JL
Take a look at the Clarification of requirements for VW2009 Mac thread in the Installation Inquiries forum.
Mac users may be interested in this thread
http://discussions.apple.com/thread.jspa?threadID=1811637&tstart=30
It seems that with OS10.5 there is no longer any need to keep your Mac turned on at night or use something like MacJanitor, but with OS10.4 or earlier it's still a good idea to do one of them.
Welcome to the forums.
It would be helpful if you could include a signature with your system details.
For instance, if you are on the latest Mac, you won't have access to OS9 (Classic) which I think you will need to even open MiniCAD 7, so that may be your first problem.
Other forum users may be able to advise you how to upgrade once you can access the early files, but it could be that you can simply copy & paste between layers in each file.
I just completed a uni project in which I had a spiralling circulation route which passes through the various zones- each at a different level within an existing building.
Ah, didn't we all do a Uni project like that?
Malte, there are no hard and fast rules when it comes to split levels - you decide how to set it out, depending on the parameters of your particular design. Floors can be at any level within, above or below a layer - you can have a layer for each and every level, or you can have just one layer with all the floors set out relative to it, or (probably) something in between. It does get complicated with overlapping levels, and I would be interested to know how others cope with that.
In the case of an existing building, I would start with layers for each existing floor level plus the roof, because you have to show the existing for the Council and the existing exterior walls and roof will be easier to draw, then look to set out the new levels relative to those layers, which is how it will actually be built as well.
Are you looking at a model or a viewport?
If you've added lights since you created the viewport, the new lights might be in a new class, which you then have to turn on in the viewport.
It may help if you could compose a signature with your system details.
Oops, should have read other postings first.
Billtheia mentioning Exporting to PDF seems to work - thanks Bill.
I no longer have an A1 printer, but I want to draw in A1 and send PDF's to a bureau for printing.
However, I can't get VW to accept an A1 page size - it keeps breaking it up into A3 page sizes, presumably because that's the largest page size my present printer will do.
Does anyone know how to get VW to use a page size outside those of a plugged in printer?
Maybe this is a class issue - I notice your Fill and Pen attributes aren't selected for Class Style, unless they show differently in v2009. It sounds like there is a over-riding class with white fill involved somewhere.
Is the truss in its own class, set up the way you want, including texture?
If you go into the truss group (double click, not ungrouping it) what class are all the constituent members? They may have to be individually classed and textured.
In your Attributes palette, with nothing selected, are all Fill and Pen boxes set to Class Style/Color? I use None as my default class, with the Fill and Pen boxes set up like that, then I change the class of an object once it's created, and the object then adopts the new class characteristics.
Nick
As well as having the walls in a class, and with a class texture selected, you may have to check that each wall individually has texture selected correctly as well.
If you are rendering via a viewport, check that the wall class is selected for that viewport.
Bill
Sorry to divert the post momentarily but .....
New iMacs? Are they imminent? I have to upgrade as my lease runs out soon, but I haven't heard any whispers of a refreshed lineup.
Oh no, that was my standard advice being rubbished, no doubt about it.
Well Ray, we have been told off well & truly, haven't we?
Best you stick to PC's, and I'll.......... retire!
Try some Mac maintenance - my apologies if you already know these .......
1. Restart (I guess you've done that).
2. Run Utilities>Disk Utility>Repair Disk Permissions.
3. Leave your Mac on overnight, or download a program called MacJanitor and run it weekly.
4. Buy a program called DiskWarrior and run it weekly.
HTH.
My Mac has 1 GB of memory, which I'm guessing is not enough. How much memory is needed on the computer and/or plotter in order to print a file like mine? Is it as simple as buying more memory and plopping it into the hard drive?
It depends on your Mac - it may have room for an additional module(s) or you may be able to replace your existing module with say a 2GB. But they plug into slots inside the machine, they have nothing to do with the hard drive. Perhaps you should check with your Mac supplier to see what can be done with your particular Mac - it may be that the cost to upgrade makes a new machine feasible.
When you upgrade beyond VW11.5, you will need more memory (at least 2GB, 4GB better), especially for high end renders like your gorgeous illustration.
Brilliant! Just what I wanted.
I had to make a Saved View for the 2 layers to show properly, but it works just fine.
Thanks for the tip.
I am drawing sections of a house in 2D (sketch plan stage) and want to show sunlight at midsummer and midwinter, entering the door and clerestory window on one side and crossing the side wall.
I'd like to be able to draw a filled shape for each and colour them differently, but they need a degree of transparency so the area common to both shows as a third blended colour.
Does anyone have any suggestions as to how that might be done in VW?
Pepsi
There are other posts about this, and a mute button has been added to the home page.
If you're going to surf the web at 2am, maybe you should mute your computer first, or surf in another room, but don't blame someone else if you have a problem.
Nick
Welcome to the forums. As you can see, there are some very funny(?) people here.
It is helpful if you put a signature on your posts, so we can see what system you are running.
You incorporate a basement level by using Layers. You can leave the ground floor layer as Level 0 and give the basement floor a negative level or you can start with the basement floor at 0.
Please add a signature that describes your hardware and software.
You get WinDoor as part of the Aus/NZ package - you can draw most configurations with that.
If you have problems, email Julian Carr at OzCad, join Jonathan Pickup's User Group, or buy one of Jonathan's Archoncad manuals.
Gary
It would help if you added a signature describing your system.
In answer to your question - it might depend on whether you design buildings or landscapes. Mar is probably right if it is the former.
Brudgers
I don't consider auto-join walls a user error, I just don't use it myself because
1. it's a hassle if you subsequently move the wall (you have to use the Heal tool as well);
2. the wall as in CS1's case ends at the centre of the cross wall, so of course Fit To Roof isn't going to work the way he thought it would.
One swell foop!!!! I love it.
I assumed CS1 had unjoined the walls. I don't T join walls as a rule any way, unless I have to join components.
CS1, I don't think it's a bug - the program apparently works to a higher degree of accuracy than 2 decimal places, as Pete A has described. Claiming something is a bug when it doesn't work the way you think it should is a Chicken Licken response that is a bit too common on these forums.
The thing is - did our suggestions work and has the wall sliver disappeared?
Tech Forum Link....
in General Discussion
Posted
Jeffrey
Thank you for the suggestion.
After Restart however, going on the Board site generated 2 cookies, which I deleted. Then my first first log-in failed as usual, but generated 7 cookies.
The 2nd log-in succeeds, whether or not I delete the 7 cookies.
Are you suggesting I set my Mac to deny all cookies?
