KingChaos
262 -
Posts posted by KingChaos
Thanks Dom, i have to check.
Ah now it works thanks.
Additional question, "is it possible, to have some variables not beeing "named" by condition or otherwise deleted out of hte oip?"
f.E.
If my POlyline has 4 segments, i would like to have the inputvariables height and Width of the 5. and 6. Object are not beeing shown in the oip.
BR KC
There is No constraints on the center
Hey,
maybe i am too stupid but nothin happened ^^ except crashing VW a few times.
The debug tells me "True" so VW was succesful to placing my value into the database of the 3D-Cabinet, but the Cabinet is still in original dimension.
It named the symbol in the group exactly what i wanted, but something is not right, i dont get what it is.
sprich ruhig deutsch 🙂 oder PM ok?
hi Gregi,
the Master is the symbol, which contains all the other symbols and has an OIP where u can manipulate the height and Depth of the cabinets. The Length is driven by the segmentlength of the polyline (controlgeometry).
u can PM me, if u have some time to have a look.
Maybe some addable constraints, orthogonal, parallel and coincident would solve this, but i dont know how to place them
of course i knew this "crashing all the sketch segments" from TopSolid.
But there u can repair all the stuff because u simply have to manipulate the points and direction, where the dimensioning is.
It was really headache in the start, but did u once get how it works its working for u 🙂
Dont use the T.. ..... Word 🙂 or i am going to cry.
Hi,
totally naive i made a red symbol out of a Cabinet 3D from the extragroup.
Now i try to put in database entries for width/length and Height into my symbol.
Can someone please give me some hints, how to go further?
in the "Data-Manager" i find something, but only
The Symbol definition does not contain my red saved symbol i made out of the 3D-cabinet.
in plug in of third parties i find something "Korpus", but not my red symbol
what is the plan i have to follow?
are the nodes i find to use some database stuff.
BR KingChaos
but it would be great to have some "vector to angle" node.
yeah offset the single lines half the objects width makes it.
Hi,
I have to move some objects in an angle but i only got vectors, so i dont know how to calculate a vector out of an angle and there is only "vector to angle" node.
MAybe someone has a reverse node or knows how this goes better with different nodes.
I have a list of path extruded rectangles along lines, which generated out of a polyline (red).
But the profile which is extruded allways is "placed" in the middle (center of bounding box) of my path extrude.
But I need this extrudes BEHIND or INFRONT the line (The Profil has to be extruded in the edge of my ).
So i thought i can read out a list of angles of the lines and use the "MOVE" node to move the Boxes half height and half width.
But the node needs a vector not an angle.
BR KC
i got it,
but how to drive any value into given marionettes with input variables?
Ok i know how to place a symbol, but how u put in the variables into all by marionette placed symbols?
I can imagine, that some kind of "get input variables" into a list and then put the global variables of your main marionette into the placed symbols?
Hi there,
which Node i need to split a poly into a list of lines?
I am trying to make a path extrude along a polyline, but not as 1 object along the hole polyline.
Each segment should be a path to extrude a geometry along it without connection to 1 object along the poly.
br KC
Hi Pat,
thx.
Thats clear, but it was confusing, that such constraining is not working between objects.
There is results a modification of one thing overrides the existing constraint?
If I try to constrain different rectangles, it is modifying those "other constraints".
Is there any "horizontal" or "orthogonal" contraint i can place manually?
But what is happening in the 2. clip? The measures are tipping, after i made it 0 and then with some input >100.
br THX kc
hi there,
can someone tell me, whats wrong with those ass. dimensioning?
I am trying to find the logic behind it.
How can i place some constraints (parallel, othogonal, incidence ..), so that VW wont destroy my sketch/associative dimension?
When do u suggest to use this associative dimensioning, what for it was made, does someone use it?
f.E.
I made a polygon and used the object dimensioning to learn something about it.
Sometimes (the left and upper part of my polygon) it works on all 3 anchor points, while i input diff values into the dimension, the right and bottom one only works on one of the anchor points without destroying themselves.
BR KC
sounds like he wants to drive a lot of marionettes having the same input variables with one parameter in the file were he wants to place them.
Hi there,
is it possible to set some measures/dimensioning into marionette created objects?
f.E. i will make a block with marionette and i would like to have x,y and z measures like vw does?
BR KC
Is here anyone, who ever copied a pythoncode into a script in VW to use it in the BOM charts?
does someone knows, what of the code the wrapped marionette i have to copy into my script editor?
import Marionette
import math
import operator
Marionette.execution_mode = Marionette.ExecutionType.Export
###################### IfInStringABS_Wrap_79 #########################
class IfInStringABS_Wrap_79:
Handle = vs.Mrntte_GetNodeHandle(79)
@Marionette.NodeDefinition
class Params(metaclass = Marionette.OrderedClass):
this = Marionette.Node("Wrapper")
this.SetDescription("""Wrapper""")
this.SetLinksObjects()
InputKante_60_Lifted = Marionette.OIPControl( 'InputKante', Marionette.WidgetType.Int, 134)
InputKante_60_Lifted.SetDescription("An OIP control that accepts integer values")
KantenNr_61_Lifted = Marionette.OIPControl( 'KantenNr', Marionette.WidgetType.Int, 2)
KantenNr_61_Lifted.SetDescription("An OIP control that accepts integer values")
ABS_Output = Marionette.PortOut()
ABS_Output.SetDescription("The result item")
def RunNode(self):
###################### String_62 #########################
class String_62:
Handle = vs.Mrntte_GetNodeHandle(62)
#COMMAND;READONLYREFFILE;[VWLibDef]/Input\String.py;
#Modified April 2017
#APPEARANCE
#Name
this = Marionette.Node( 'String' )
this.SetDescription('A text string defined in the OIP')
#Input Ports
#OIP Controls
String = Marionette.OIPControl( 'string', Marionette.WidgetType.Text, '')
String.SetDescription('A text string')
#Output Ports
s = Marionette.PortOut()
s.SetDescription('The string')
#BEHAVIOR
def RunNode(self):
#inputs
s = self.Params.String.value
#script
#outputs
self.Params.s.value = s
###################### String_89 #########################
class String_89:
Handle = vs.Mrntte_GetNodeHandle(89)
#APPEARANCE
#Name
#Input Ports
#OIP Controls
#Output Ports
#BEHAVIOR
def RunNode(self):
#inputs
#script
#outputs
###################### InputKante_60 #########################
class InputKante_60:
Handle = vs.Mrntte_GetNodeHandle(60)
#COMMAND;READONLYREFFILE;[VWLibDef]/Input\Int.py;
#APPEARANCE
#Name
this = Marionette.Node( 'Int' )
this.SetDescription('An integer value')
#Input Ports
#OIP Controls
Int = Marionette.OIPControl( 'Integer', Marionette.WidgetType.Int, 0)
Int.SetDescription('An OIP control that accepts integer values')
#Output Ports
i = Marionette.PortOut()
i.SetDescription('The value')
#BEHAVIOR
def RunNode(self):
#inputs
i = self.Params.Int.value
#script
#outputs
self.Params.i.value = i
###################### KantenNr_61 #########################
class KantenNr_61:
Handle = vs.Mrntte_GetNodeHandle(61)
#APPEARANCE
#Name
#Input Ports
#OIP Controls
#Output Ports
#BEHAVIOR
def RunNode(self):
#inputs
#script
#outputs
###################### If_In_String_70 #########################
class If_In_String_70:
Handle = vs.Mrntte_GetNodeHandle(70)
#COMMAND;READONLYREFFILE;[VWLibDef]/String\If In String.py;
#added to library 02/28/2018 MFarrell
#APPEARANCE
#Name
this = Marionette.Node( 'If In String' )
this.SetDescription( 'If a sub string exists in the given full string, this node returns True, if not, it returns False.' )
#Input Ports
sFull = Marionette.PortIn( '' )
sFull.SetDescription( 'The full string to search' )
sSub = Marionette.PortIn( '' )
sSub.SetDescription( 'The sub string' )
#OIP Controls
#Output Ports
b = Marionette.PortOut()
b.SetDescription( 'True or False, depending on whether the sub string is in the full string' )
#BEHAVIOR
def RunNode(self):
#inputs
full = self.Params.sFull.value
sub = self.Params.sSub.value
#script
bool = []
if str(sub) in str(full):
bool.append(True)
else:
bool.append(False)
#outputs
self.Params.b.value = bool
###################### ABS_Output_83 #########################
class ABS_Output_83:
Handle = vs.Mrntte_GetNodeHandle(83)
#COMMAND;READONLYREFFILE;[VWLibDef]/Data Flow\If.py;
#Modified by MFarrell May 2017
#APPEARANCE
#Name
this = Marionette.Node( 'If' )
this.SetDescription( 'If test is true, pass the value from true otherwise pass the value from false' )
#Input Ports
true = Marionette.PortIn( None, 'itemTrue' )
true.SetDescription( "An item" )
false = Marionette.PortIn( None, 'itemFalse' )
false.SetDescription( "An item" )
test = Marionette.PortIn( True, 'bTest' )
test.SetDescription( "A boolean value" )
#OIP Controls
#Output Ports
out = Marionette.PortOut('item')
out.SetDescription( "The result item" )
#BEHAVIOR
def RunNode(self):
#inputs
test = self.Params.test.value
true = self.Params.true.value
false = self.Params.false.value
#script
if test:
out = true
else:
out = false
#outputs
self.Params.out.value = out
if Marionette.execution_mode != Marionette.ExecutionType.PIOExecute:
vs.BeginGroup()
String_62.Params.String.value = """ABS"""
String_62.Params.s.SetConnected( True )
if String_62.Params.this.initFunc:
String_62.Params.this.initFunc(String_62)
String_62.RunNode(String_62)
ABS_Output_83.Params.true.value = Marionette.OutputMerge( ABS_Output_83.Params.true.value, String_62.Params.s )
ABS_Output_83.Params.true.blocked = ABS_Output_83.Params.true.blocked or String_62.Params.s.blocked
if String_62.Params.this.finalFunc:
String_62.Params.this.finalFunc(String_62)
Marionette.NotifyForOutValue( String_62, 0, String_62.Params.s )
String_89.Params.String.value = """ """
String_89.Params.s.SetConnected( True )
if String_89.Params.this.initFunc:
String_89.Params.this.initFunc(String_89)
String_89.RunNode(String_89)
ABS_Output_83.Params.false.value = Marionette.OutputMerge( ABS_Output_83.Params.false.value, String_89.Params.s )
ABS_Output_83.Params.false.blocked = ABS_Output_83.Params.false.blocked or String_89.Params.s.blocked
if String_89.Params.this.finalFunc:
String_89.Params.this.finalFunc(String_89)
Marionette.NotifyForOutValue( String_89, 0, String_89.Params.s )
InputKante_60.Params.i.SetConnected( True )
if InputKante_60.Params.this.initFunc:
InputKante_60.Params.this.initFunc(InputKante_60)
InputKante_60.Params.Int.value = self.Params.InputKante_60_Lifted.value
InputKante_60.RunNode(InputKante_60)
If_In_String_70.Params.sFull.value = Marionette.OutputMerge( If_In_String_70.Params.sFull.value, InputKante_60.Params.i )
If_In_String_70.Params.sFull.blocked = If_In_String_70.Params.sFull.blocked or InputKante_60.Params.i.blocked
if InputKante_60.Params.this.finalFunc:
InputKante_60.Params.this.finalFunc(InputKante_60)
Marionette.NotifyForOutValue( InputKante_60, 0, InputKante_60.Params.i )
KantenNr_61.Params.i.SetConnected( True )
if KantenNr_61.Params.this.initFunc:
KantenNr_61.Params.this.initFunc(KantenNr_61)
KantenNr_61.Params.Int.value = self.Params.KantenNr_61_Lifted.value
KantenNr_61.RunNode(KantenNr_61)
If_In_String_70.Params.sSub.value = Marionette.OutputMerge( If_In_String_70.Params.sSub.value, KantenNr_61.Params.i )
If_In_String_70.Params.sSub.blocked = If_In_String_70.Params.sSub.blocked or KantenNr_61.Params.i.blocked
if KantenNr_61.Params.this.finalFunc:
KantenNr_61.Params.this.finalFunc(KantenNr_61)
Marionette.NotifyForOutValue( KantenNr_61, 0, KantenNr_61.Params.i )
if not If_In_String_70.Params.sFull.blocked and not If_In_String_70.Params.sSub.blocked:
If_In_String_70.Params.sFull.SetConnected( True )
If_In_String_70.Params.sSub.SetConnected( True )
If_In_String_70.Params.b.SetConnected( True )
if If_In_String_70.Params.this.initFunc:
If_In_String_70.Params.this.initFunc(If_In_String_70)
maxPCnt = 0
maxPCnt = If_In_String_70.Params.sFull.MaxLen( maxPCnt )
maxPCnt = If_In_String_70.Params.sSub.MaxLen( maxPCnt )
if If_In_String_70.Params.this.nodeListAbsorb or maxPCnt == 0:
try:
If_In_String_70.RunNode(If_In_String_70)
except:
Marionette.ReportException()
ABS_Output_83.Params.test.value = Marionette.OutputMerge( ABS_Output_83.Params.test.value, If_In_String_70.Params.b )
ABS_Output_83.Params.test.blocked = ABS_Output_83.Params.test.blocked or If_In_String_70.Params.b.blocked
else:
p0List = If_In_String_70.Params.sFull.ExtendList( maxPCnt )
p1List = If_In_String_70.Params.sSub.ExtendList( maxPCnt )
out0 = None
out0blocked = False
for p0, p1 in zip(p0List, p1List):
If_In_String_70.Params.sFull.value = p0
If_In_String_70.Params.sSub.value = p1
try:
except:
out0 = Marionette.OutputMerge( out0, If_In_String_70.Params.b )
out0blocked = out0blocked or If_In_String_70.Params.b.blocked
If_In_String_70.Params.b.SetValue( out0 )
If_In_String_70.Params.b.blocked = out0blocked
if If_In_String_70.Params.this.finalFunc:
If_In_String_70.Params.this.finalFunc(If_In_String_70)
else:
If_In_String_70.Params.b.blocked = True
ABS_Output_83.Params.test.blocked = True
Marionette.NotifyForOutValue( If_In_String_70, 0, If_In_String_70.Params.b )
if not ABS_Output_83.Params.true.blocked and not ABS_Output_83.Params.false.blocked and not ABS_Output_83.Params.test.blocked:
ABS_Output_83.Params.true.SetConnected( True )
ABS_Output_83.Params.false.SetConnected( True )
ABS_Output_83.Params.test.SetConnected( True )
if ABS_Output_83.Params.this.initFunc:
ABS_Output_83.Params.this.initFunc(ABS_Output_83)
maxPCnt = 0
maxPCnt = ABS_Output_83.Params.true.MaxLen( maxPCnt )
maxPCnt = ABS_Output_83.Params.false.MaxLen( maxPCnt )
maxPCnt = ABS_Output_83.Params.test.MaxLen( maxPCnt )
if ABS_Output_83.Params.this.nodeListAbsorb or maxPCnt == 0:
try:
ABS_Output_83.RunNode(ABS_Output_83)
except:
else:
p0List = ABS_Output_83.Params.true.ExtendList( maxPCnt )
p1List = ABS_Output_83.Params.false.ExtendList( maxPCnt )
p2List = ABS_Output_83.Params.test.ExtendList( maxPCnt )
out0 = None
out0blocked = False
for p0, p1, p2 in zip(p0List, p1List, p2List):
ABS_Output_83.Params.true.value = p0
ABS_Output_83.Params.false.value = p1
ABS_Output_83.Params.test.value = p2
try:
except:
out0 = Marionette.OutputMerge( out0, ABS_Output_83.Params.out )
out0blocked = out0blocked or ABS_Output_83.Params.out.blocked
ABS_Output_83.Params.out.SetValue( out0 )
ABS_Output_83.Params.out.blocked = out0blocked
if ABS_Output_83.Params.this.finalFunc:
ABS_Output_83.Params.this.finalFunc(ABS_Output_83)
else:
ABS_Output_83.Params.out.blocked = True
Marionette.NotifyForOutValue( ABS_Output_83, 0, ABS_Output_83.Params.out )
self.Params.ABS_Output.SetValue( ABS_Output_83.Params.out.value )
self.Params.ABS_Output.blocked = ABS_Output_83.Params.out.blocked
vs.EndGroup()
try:
IfInStringABS_Wrap_79.Params.InputKante_60_Lifted.value = 134
IfInStringABS_Wrap_79.Params.KantenNr_61_Lifted.value = 2
if Marionette.execution_mode != Marionette.ExecutionType.PIOExecute and IfInStringABS_Wrap_79.Params.this.nodeLinksObjects:
vs.BeginGroup()
if IfInStringABS_Wrap_79.Params.this.initFunc:
IfInStringABS_Wrap_79.Params.this.initFunc(IfInStringABS_Wrap_79)
IfInStringABS_Wrap_79.RunNode(IfInStringABS_Wrap_79)
if IfInStringABS_Wrap_79.Params.this.finalFunc:
IfInStringABS_Wrap_79.Params.this.finalFunc(IfInStringABS_Wrap_79)
vs.EndGroup()
if Marionette.execution_mode != Marionette.ExecutionType.Export:
vs.Marionette_LinkObject(IfInStringABS_Wrap_79.Handle, vs.LNewObj())
Marionette.NotifyForOutValue( IfInStringABS_Wrap_79, 0, IfInStringABS_Wrap_79.Params.ABS_Output )
except Marionette.MarionetteError:
pass
Hi,
i am trying to convert a number from 1-4 digits into a predefined text.
Input is this "1 to 4" digit-number, which can be a and an single-digit (1,2,3 or 4) which has to be compared whether the single digit is contained in the 4 digit.
The script has to return a string "ABS" if the input is:
1234 & 1 -> ABS 1 is included
234 & 1 -> "" 1 is not included
312 & 1 -> ABS
i dont know which node i have to use. I searched for some who splits the 4 digit into 4 single digits, but i cant find it.
This Script i have to use in a bom-Chart for interiorcad.
I would rather use the excel functions, but this function does not work in the vw chart i think or i am not able to find the syntax i have to use.
If someone can tell me, how the syntax of this function is, i dont need the marionette.
BR KC
If U want to make such parametric stuff in a few minutes try topsolid.
In Case U want to produce your 3d stuff on cnc machines, U need years for each Module with vw.
BR kc
Node - Text along a line?
in Marionette
Posted
Hi There,
is there any node making a text along a line?
I will need it parallel to the line in the middle with a small offset.
BR KC
