Thank you Joshua! Your suggestion has resolved this issue for me. Opening a new document, the Lighting Pipe tool functions correctly, showing pipe geometry in 3D views, so I thought I must have accidentally gotten into a mode where these objects lost their hybrid-ness, but couldn't find what it is. Resetting the EAP options was the trick.
For completeness:
I'd been working on this document for a few weeks and the Lighting Pipe tool was functioning correctly, as it has in previous documents and previous versions. Today, when creating a new Lighting Pipe, it no longer created a hybrid object. It only displayed the 2D representation even when rotating the view into 3D. This is further evidenced by the fact that the new Lighting Pipe objects have the Plane field in the OIP with options of 3D or Screen. Lighting Pipes I had previously created in this document do not have the Plane field. The existing Lighting Pipes were still rendering in 3D while new ones were only 2D up until the point I tried duplicating one of the existing objects. The duplicate became 2D with the Plane field in the OIP, but so did all of the existing Lighting Pipes that were previously fine. (I'm still sorting out if there's a good way of restoring them, now that the EAP settings are fixed, without redrawing them all.)
Additionally, I noticed that this might also be affecting the Lighting Ladder tool. Creating a new ladder and rotating into 3D, the internal rung pipes are appearing in 3D, but the rectangular frame does not appear at all (as either 3D pipe or the 2D line).
Thank you again.
