436 -
Posts posted by Ethan R.
Can someone who does have VectorWorks and the Space Navigator functioning happily post up an importable configuration file?
Thank you
S_
so simple and needed. Iso & Plan view at the same time anyone?
Available in all cheapy programs.
ah - this is the spotlight plug-in. Else it would be easy
The "Television" tool
Thanks Kevin,
Wouldn't the PlasCase texture then be in my Document's resources? I don't see it there.
Trying some of the others. Please advise.
I'm hoping this is very simple.
I have a bunch of TV objects - but the cases keep rendering in Gray. For the life of me, I can't figure how to get the cases to render in the black plastic they are made out of??
thanks in advance
E_
wow major help with this post!
Thank you!
ethan
ahh - i am and I can try ... let me see
thanks!
Our wall is 60'w x 13' tall - it would be a killer to process all those cutouts! LOL!
Thanks - Just posted the low-Res LED question to the board.
No curved option on the tool is a drag.
thanks!
Ethan
Trying to give the client the correct visual for our concept ...
We have an 18mm background screen and a 5mm HD Content Screen which floats in front.
I want to show the pixel density difference between the two products.
I've been killing myself trying different masks, but nothing seems to work out correctly.
Does anyone have a way to render Low-Res LED walls?
Thanks
2010 wish list - does it exist yet??
Agreed -
this tool could be useful - but is way to clunky.
Why not have the ability to build in aisles so you can set your general seating area and get a seat count?
seems like many a throw in on the "not worth it" spotlight package. Really I feel I payed for some kind of useful, but fairly half-baked plug-ins.
I was thinking of upgrading my input devices for mac. Was looking at a 3D Controller like the Space Navigator
Does anyone have any experience with this and VectorWorks?
Moderator - anyone? Hello?
thanks -I'll try that
trying to correctly texturize some cabinet symbols and do not have full texture controls? Advice please.
thanks
My stacked layers command is greyed out in my current document. Any idea why?
Hmm.. Why can't I get the mapping preferences for the door object? I need to adjust the scale of the map used.
On the class leval, you can't adjust the map either ..
Got it! Thank you!
Trying out the help, thank you ..
Actually having problems finding where to "double click" the extrude along path ..
Hi
I'm trying to extrude along a path. However, when I extrude, the center of the object is centered to the path, and I need the edge along the path.
As a solution, I have offset the path 1/2 the width of the object to be extruded. This in theory should put the edge of the extrusoin at the edge of the path I need.
However, I am getting an error message when trying to extrude along the offset path?
Please see the file here .. http://www.aaaeventservices.com/test.mcd
thank you,
Ethan
No I'm getting nothing from VectorWorks & nothing from Nemetschek!!!
I've called, emailed, webformed and left messages!!!
Nothing!!
I believe I am having the same problem.
I get the VW splash screen, but then it dissapears and I have nothing.
is this what you are experiencing?
thank you,
Ethan
Did you do the full un-install, delete reg, re-install or just delete the registeries and run the program?
Thanks
E
Countersink Holes
in Solids Modeling
Posted
Hello All -
I?m using some flat head machine screws to hold some boards together and I would like to create a countersink hole. It seems pretty straight forward, but I can't seem to figure out how to create a tapered extrude to cut the hole.
Screw is:
.477" Diameter Head Tapers at 85? for .133" to 1/4" Diameter, and then the rest of the screw ...
thoughts?
