Scott that's quite helpful, and provided a good example to build a distributor label worksheet that works for me.
What I'm still struggling to achieve, though, is generate a worksheet that understands what each end of a data cable is connected to. I believe they're correctly associating with the distributor objects, as if I drag the distributor the cables follow and adjust length etc automatically... but I can't find where VW is acknowledging the start/end nodes so that I can try to reference it in the worksheets. In the OID for a drawn data cable, START and END aren't fillable boxes, which suggests that they're calculated based on the distributor objects' parameters... but nothing I enter in the distributor objects' own OID seems to transfer there or show up in a worksheet. Do you have any idea what I'm overlooking?
Thanks
