Hi Marissa
I've edited the network:
- Added the first two nodes you suggested. In an earlier try I had this:
Then as a part of the several attempts I made, I removed the first two nodes.
- The second edit I've done, is the adding of a second parallel part, which should give different, new attributes to objects that have the same starting attributes, but have a different class (the class name contains _aus , instead of _ein):
I hope it's clear...
Then 2 things about the node "Objs by Crit":
1- If I copy one from one drawing and paste it in another, it won't work. I have to edit the criteria because the primary color seems to change in different files...
2- When I open the criteria configuration menu I have to set all criteria manually. The menu does not seem to remember which criteria had been set earlier.
Thank for helping me out
Luca
Import_Schleppkurven - Versand_181221.vwx
