drs1706
    4
Everything posted by drs1706
  1. Hi Everyone, Problem fixed (randomly). I found separate folders for resources in application support that were empty. I copied the Lysaght file into the same folder as the Vectorworks library file structure and Hey Presto, everything was searchable again. I deleted the file i had just copied as two sets of hatches appeared in the search and it's still working for everything. For info: Left window file path: User>(username)>Library>Application Support>Vectorworks>2019>Libraries. These are the empty folders. Hope this helps should anyone else have this strange bug (why do these things always seem to happen to me!). Cheers D PS: Sorry if this is hard to follow, thats why im not a teacher!
  2. @Rob Books Hi Rob, tried everything i can think of and no luck. D
  3. Hi Guys, For info: Tried refreshing Libraries, no dice. Saw your edit zoomer, cheers. I updated last Friday so everything has been restarted at least a couple of times since. Doesn't matter what I'm searching for (linetypes, symbols, hatches etc) even set on all resources the search doesn't work. I can manually go looking for them (and find them) but that means remembering which folder the resource is in. Cheers D
  4. Since upgrading to 2019 SP3, when i use the search bar it will only find items that are in the current doc or my favourites. As you can see from the attachment, Lysaght files are available and I can manually find them but a search doesn't return any results. This goes for anything and everything. Is there a setting I'm missing or is there something wrong with my VW? I'm running macOS High Sierra 10.13.6 for info. Cheers D
