![](https://forum.vectorworks.net/uploads/set_resources_20/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Mi&D
76 -
File Comments posted by Mi&D
Hello
May I ask for an info about the apartment tag / apartment stamp 1.2.5?
When I change the room style - e.g. from "SIA Ausführung II" to "SIA Baueingabe" -
then I do not manage to put it backwards on execution afterwards.
It would be great if it were possible to switch back and forth between these 2 room styles.
Would that be possible?
PS: Why the room style in the accessory manager is once red and once green? -
Hello,
seems realy interesting.
But: I am not able to open this file in VW 2018 SP4.
Why is this so?
Mi&D
hello DomC,
in the Swiss VW-Forum some users are developing a methode similar to your marionette "apartment area". see #38 on
https://www.vectorworksforum.de/Thread-VW-Raumgruppe?page=4
moreover this marionette should write the area of all spaces with the same Room ID in a database.
after this we can use mutli-stamp which takes this information from the database for getting the data on our plans.
In the end it should be possible to make a legend based on this data.
could you help me with this?
how can we program the marionette, so that it attaches the apartment area in each and every room of that apartment?
I would be very thankful.
Mi&D
Hello DomC,
thanks for reply!
1. yes. correct.
2. also correct
3. With the help of some colleagues in VW-Forum we developed - based on your marionette - a marionette in which we can adjust the text format and -style.
Concerning the symboI-issue : I wasn't aware so far, that it affects the performance of the marionette whenever it is a symbol or not...Could you please give me a hint, were I can get more information about this topic...
thanks, Mi&D
See the test file, I've described above.
Hi DomC,
thanks for reply.
As you can see in the uploaded images, I am using Room ID.
Nevertheless the Marionette Stamp is not displaying the area...
I tested the Marionette in a new file, in which i copy/pasted 3 spaces.
I copy/pasted the Marionette from your Apartment Area.vwx. As soon as I move it or actualize it, the line spacing isn't working anymore.
But the area m2 stays ok. Which is not the case in the file I've sent you on wetransfer. How come?
1
Thanks for Reply. DomC
In the following I try to reproduce what I did:
1. copy/paste the "area marionette" from "Appartment Area.vwx" into my file. I change the Room ID from "B.2" into "2301" and actualize. In this moment the m2 line
disappears.
In the other hand I've noticed that even though it is in my file, the stamp still shows the m2 area of "Appartment Area.vwx". As soon as I move the stamp, the area m2 disappears. I didn't find a way to make it show up again.
Another user recommended me to transform the marionette object into a wrapper node, and the edit the marionette, to transform it again into an object node.
But even this didn't work.
the file is very large, I uploaded it on wetransfer: Here is the Download-Link
https://we.tl/t-BzWyq6MajS.If you could have a look at it, would be great.
Mi&D
Hallo DomC,
thanks for this post and the tool. It's great!
I am using this marionette. But, still...there are some issues.
As soon as we move the stamp, the area text disappears.
The same happens when we rotate it.
If we change the scale from 1:50 to 1:100 the line spacing of the stamp does not work.
Is it possible to repair this bugs?
cheers, Mi&D
Apartment Tag / Wohnungsstempel
in Marionette - Networks
Posted
Ok, thanks for your explanation DomC. I got it.
There was a miss-leading thought I've had. It's not the style I need to change, but it's in the properties setting of the stamp.
When I want to show a simpler Stamp with less info, than I need to change the room stamp symbol (Show symbol 1, or 2, or 3, ...).
Sorry about the inconvenience...
Mi&D
