ckrueger83
    3
Everything posted by ckrueger83
  1. Hello, Another hiccup with Vectorworks. This time, I cannot for the life of me get my drawings to take up the whole sheet when exported to pdf. I've attached several images with the problem I'm facing including Adobe's printer setup, my page setup within VectorWorks, and the result of my settings. There is a very large, white border around my titleblock despite it being set to the size of the sheet. What am I missing? What option haven't I checked/ticked? 18009_VA_Sioux Falls_Building 38_FJ100.pdf
  2. Hello, In my project floor plan, I've placed a number of doors. However, the ID Tag text size is microscope, so much so that it's not visible on print outs. As far as I can tell, there is no way to change the size of this text, and my current work-around is to create a group of text within a circle, drop that in all my doors, and edit as I go, which is hardly efficient. Attached are screenshots of my problem. Any help is appreciated.
  3. Hello, Our company currently heavily uses Revit, and to a lesser extent ArchiCAD, and now I've been tasked with learning VectorWorks for upcoming projects. Let's just say the learning experience has been interesting! What I'm attempting to do at the moment is have data that is placed on the cover sheet, such as project name, project location, project number, and date (information that would not change sheet to sheet), be changed/updated across all sheets. The company titleblock cover sheet we use has multiple places for project name, address, and number, and I've got linked text to those lines, and when I update one of those, all of the locations on the cover sheet will update, which is great! However, I would like this information across ALL sheets to be changed as well, otherwise I don't see the benefit of using linked text to records if I have to manually change each sheet. "Use automatic drawing coordination" is turned on, and I have attached the record format I've created. I've also got my titleblocks (cover sheet and standard titleblock) grouped and saved as symbols. Any help would be appreciated. I'm sure I'll have additional questions as I dig into VectorWorks.
