Link
    12
Everything posted by Link
  1. Hi there, can any one remind me how to scale down the title block size. I know it’s on the OIP but I can’t remember the format I used to scale down. I know it’s simple but I can’t remember. thanks
  2. Hi, I’m trying to compile a Hardscape Budget Report in VW LANDMARK 2016. It’s usually in the resource browser. I can’t find it anywhere. Any ideas? Thanks.
  3. Yes, I’ve tried the MODIFY>ALIGN>DISTRIBUTE LEADER LINE. Unfortunatrly, the label Lind is still running through the text or is otherwise too far away from the text. I don’t know what else to try???
  4. The distance on the label point on plant tags seem to have changed. The line either runs through the text or is too far away from the text. It was working fine with all the text nicely justified to the label point. When I move the label point the text moves with it. Is there a way to set the distance back to how I had it?? Thanks
  5. I’m having problems with plant tags. The spacing between text and plant tag line is too far apart or the plant tag line runs through the middle of the text. Any ideas?? Thanks
  6. The distance on the label point on plant tags seem to have changed. The line either runs through the text or is too far away from the text. It was working fine with all the text nicely justified to the label point. When I move the label point the text moves with it. Is there a way to set the distance back to how I had it?? Thanks
  7. The distance on the label point on plant tags seem to have changed. The line either runs through the text or is too far away from the text. It was working fine with all the text nicely justified to the label point. When I move the label point the text moves with it. Is there a way to set the distance back to how I had it?? Thanks
  8. I’ve just shut down and restarted and it now seems to be working. Thanks so much for your reply. Sarah
  9. The fields are there but are just sitting blank. They are not showing the class and layer of individual objects. Just blank. I’m not sure if I have changed a setting without realising or if a problem with the software?
  10. For some reason when I select an object, the class and layer is not displayed on the OIP. All of the other info is there. It has been working fine until I logged on today. Any ideas?? Thank you. Sarah
  11. Thanks Kevin. It works a treat. Thanks Ric, I’ll give it a go. Much appreciated.
  12. I’m trying to get a visible running measurement on a curved line(arc). I want to mark intermittent points on the line. Can anyone help?? Thanks
