ZachCiaburri
5 -
Posts posted by ZachCiaburri
Hello -
Normally when I want to slightly move a single instruments label legend symbols there is a little blue anchor point. For some reason it is missing on this specific drafting - my selection tool IS set to " Single Object Interactive Scaling Mode" so that shouldn't be the problem.
Thanks in advance!
Undocking and redocking fixed the issue. I can't imagine thats working as intended haha. Thanks a lot.
For some reason my Attribute palette is just blank and gray. I've had this issue with the object palette before as well but luckily when using spotlight you can use the instrument insert tool to select your instrument. I have no clue how to fix this. I have restarted vectorworks numerous times, I have used different files. No matter what line or shape tool or even text tool I select there is no option for attributes.
Augment3d plug-in messed up my save function
in Troubleshooting
Posted
I am using Vectorworks 2021 on MBP 2016 w/ touchbar Intel, I installed the Augment3d plugin. I then found out that that plug-in is not compatible with 2021. Ever since I have installed this plug-in File > Save, File > Save As, and File > Export As... do not launch a window/command prompt. The cursor "blinks" sort of acknowledging that it tried something but then I can just go back to using whatever tool I had selected before.
Since this problem began, I used the repair tool twice, patched SP5 and done an uninstall and re-install. Nothing works. Any suggestions?
