HI Charles,
Your plasma g-code looks like good start ! A few comments for laser cutting .
a) Cutter comp can be set to zero. Laser Kerfs are 0.010. If we need to be right on, we just adjust the hole size a bit. Our Trumpf laser actually has cutter comp built into it, but we have never used. We try to keep things as simple as possible.
b) A button to guess at and set holes to white automatically then user can click items on / off as needed.
c) Your automatic selection of lead in point looks good for 80% of the time, but need to give user ability to select 1st entity and the pierce location. Lasers can make "final" parts (most of the time) with no grinding of leadin / out points, if properly positioned.
d) Our current cam program will put all "like" entities in sub routines. Main program moves to pierce point, then sub routine turns on laser and incrementally cuts and turns off. Just a be cleaner and if you need to make adjustment, there is just one code to change, rather than maybe 50.
e) We currently use our cam program to make code, then we use our database program, "Omnis Studio" to post process to make the code just the way I like it to run on laser. Misc note : Omnis is great RAD program, we have used for 22 years, but it has never really "caught on".
f) Would need button the click on "non contour" enities to cut. Sometimes just need to cut lines or arcs that are not contours. Just allow user click then put moves in sub program. Sometimes we turn laser on / off between clicks, sometimes not. Post processor handles this now.
Why don't you email me, great2b1@aol.com off list to discuss moving forward. Maybe I can email you a quicktime movie of what we are doing now ?
Thanks, Bill Steer
