Josh Hancock
    4
Everything posted by Josh Hancock
  1. @Kevin McAllister that would be great! Thanks Kevin
  2. Hi, I am trying to create a solid from the 6 NURBS surfaces in the attached drawing. For some reason VWX is not letting me combine them. I followed the same process which has worked for me before, which is to draw the NURBS curves and then combine into separate faces... Thanks in advance! create solid from nurbs.vwx
  3. Thanks @markdd . Your way worked, and I also found another way to solve the issue. Which is to 'compose' the lines first, and then convert them into a surface. Thanks for your help.
  4. Hi, I am trying to create a surface from a series of NURBS curves. I have attached a file with just one set of the line groups that I am having trouble connecting into a surface. I think there is probably something quite simple I am missing. Any advice would be greatly appreciated. Thanks a lot nurbs to surface test.vwx
