TedCharlesBrown
10 -
Reputation
0 NeutralPersonal Information
Location
United States
Recent Profile Visitors
I am trying to export a Collada file, but it seems that I am missing Renderworks? I have done this a million times before... This is a new install, am I missing something? This menu command is not authorized for use in this product. When I start Vectorworks it says I have a license with Designer and Renderworks. Using 2020 SP2.
Hello, I am testing out the Razer Blade Stealth. I opened a document I had created using my previous laptop with an Intel Graphics 520 Internal card - and found that on the blade I received a horrible graphics bug. Starting in a render view in OpenGL and then persisting in plan view or anything else... Is this an issue with some drivers on the Razer Blade Stealth?
Label Legend changing not selected fixtures in groups.
TedCharlesBrown posted a question in Troubleshooting
Hello, I am currently working on a magic sheet for theatre. I have multiple label legends changing the containers/layout to either a master group, group, or channel. While I am doing this, I am finding that fixtures I have not said to change, will sometimes seem to be linked to the fixture I just changed. These fixtures are in an entirely different group than the one I would be working in. I find that it seems when I enter in the group, they are already selected. Changing them back to what they should be, then deselecting them before exiting the group seems to be a solution. However, it doesn't necessarily seem to make sense to have sub-selections that you can't see. Is this a known bug? or am I missing some feature to this? It really feels like I am playing Whack-A-Mole. Thanks! -
Hello, I have received a plot from a designer - however it seems that the designer used record formats, instead of using instruments. Now I know I can convert to an instrument, but this means I lose all information in the record format. Is there a way to do this without losing all information? Short from just having to redo the plot with actual lighting instruments?
- object info
- instruments
(and 1 more)
Tagged with:
- object info
- instruments
(and 1 more)
Tagged with:
Interesting, I guess from switching between a Top/Plan view and a second View pane in 3D mode my main screen changed to Top. Thanks!
Something new I am finding with 2018, is when I hover over a pdf or any object, the object turns blue. Is there any way to disable this?
2018 Standard Views / Flyover Tool Greyed out
TedCharlesBrown replied to TedCharlesBrown's question in Troubleshooting
My apologies, Like I said I very quickly opened up a new file - and didn't realize it was in a sheet layer.- 2 replies
- 3d
- standard views
(and 1 more)
Tagged with:
Hello, Quickly jumping into 2018 - looking at the new multiple view panes. I found that I am unable to view anything in 3D or different views. Even with no multiple view panes, standard views are greyed out. Is this a new restriction for the student version? Thanks!
- 2 replies
- 3d
- standard views
(and 1 more)
Tagged with:
Hello, Currently attempting to send custom drops from Vectorworks to Vision. Transparency works perfectly in Vectorworks - both using an image prop, and texture properties. However, Importing to Vision I find that it completely ignores any Transparency. Same thing with Scrim textures. Is this something Vision just can't do right now? Or am I doing something wrong. Thanks.
