elch
  • Content Count
    6
Everything posted by elch
  1. @Mike Lamb @bgoff any ideas? No solutions?
  2. Hi Mike, The file might be too big to attach (50 MB). So I created a Dropbox-link for you to download from: https://www.dropbox.com/s/yv6gfp7kks4pl0h/p80III_modell_200128.vwx.zip?dl=0
  3. Hello everyone, Is there any debugging procedure for a DGM? I have a set of modifiers, pads and grade limits, tried to adress most modifier conflicts, but there are still strange things happening in the resulting topography. For one proposed countours do odd zig-zags in unexpected places, which cannot be deleted using the "modify proposed contours" mode. It is possible to delete the extra vertices, but they just bounce right back. Also, straight and curved roads create overlapping pads which then result in modifier conflicts. Is there a way to connect them properly?
  4. @bgoff thank you for the helpful remarks. However - I spent the entire weekend trying to get the model to work - no success. Simplifying the polys scambles up everything. So I restarted with the original site data, using Pads - what happens ist still not the desired outcome. I am using pads with retaining walls and grade limits with that. There still is topography inside the building sites, but i do not understand why. Could you maybe have a look at the file and let me know, what I am doing wrong? https://www.dropbox.com/s/om2icznauy93szs/p80II_modell_v2019.vwx?dl=0
  5. @bgoff The workflow you describe is exactly what I have done, but results are not ok. See screenshots above: upper model - generated, but faulty lower model - original 3D-Polys
  6. I am looking for a way to create a site model from predrawn contour lines. When creating 3D-polys and using them with "Create Site Model", Vectorworks calculates a new and faulty topography. Ultimately I am looking for a way to calculate cut and fill, so i need to compare the new model to an existig site model. I am happy about any suggestions !
