Bill
60 -
Reputation
1 NeutralPersonal Information
Hobbies
Woodworking, music
Location
Williamsville, NY, USA
Recent Profile Visitors
Par, thanks for the education.
Hi Pat, Thanks for the pointer, I will switch to the WallThickness function. In the Define Tag Field window, I am now paying more attention to the "Data Source" and "Function" fields. I had picked the "Wall Record, Width" field because that is the first thing I saw when I created the data tag. My file started out as a v11.5 Vectorworks file. Maybe that is where the Wall Record was created and carried over when I converted to 2022. I won't spend any more time figuring that out. Question: Where can I find the documentation on the syntax for the #doc dist_1_1#, etc? Thanks, Bill
With Vectorworks 2022 I have about 10 data tag styles that are working. Now I want to create one that displays the wall width. I am close. In the Define Tag Field window: Data Source : Record Format Format Name : #Wall Record# Field Name : #Width# With this Tag Field Definition #Wall Record#.#Width# Result : 0.458 My guess was that it was the number of feet. After a little searching I edited the definition #Wall Record#.#Width# * 12.0 Result : 5.500 I ignored the extra zeroes and added a quote mark at the end to indicate feet #Wall Record#.#Width# * 12' Result : 5.4999960000000e00' I inserted a space before the quote #Wall Record#.#Width# * 12 ' Result : 5.500 ' My last step was to remove the last 2 zeroes, i.e. have a precision of 1. However, in the Define Tag Field window, the Units, Precision and Show unit/mark fields are greyed out. Question 1: What has to be added to the tag field definition to control the precision, in my case I want the result to be 5.5 I read the help here :https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Annotation2/Creating data_tag_styles.htm?rhmapfs=true#CSH_2476 In the "Editing a data tag style" section, step 8 describes the "Current Tag Field Definition" and gives some examples but doesn't point to the "language reference". Question 2: Where can I find the "language reference", i.e. the syntax for the expressions that can be entered in the Tag Field Definition area? Thanks, Bill
Hi, I'm looking at this 2022 Help webpage: https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Start/Getting_started.htm I want to create a Vectorworks application backup plan. I have a plan for my drawings and scripts. Midway down that page is a paragraph containing these two sentences: Your software license allows for one copy to be made for backup purposes. The Vectorworks application should be backed up on a regular basis. They seem contradictory. The first sentence saying one backup and the second saying regular (many) backups. Of the approximate 48,000 files that the trial version installed, I think they reside in these basic folders/directories. In the Windows 10 world the Vectorworks executable and related files are stored here: C:\Program Files\Common Files\Vectorworks 2022 C:\Program Files\Vectorworks 2022 C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Vectorworks 2022 C:\ProgramData\Nemetschek\Vectorworks Cloud Services upgrade The windows Registry contains info: Computer\HKEY_CURRENT_USER\SOFTWARE\Nemetschek\Vectorworks 27 The installation process also creates these folders/directories based on the name of the user that installed it: C:\Users\All Users\Microsoft\Windows\Start Menu\Programs\Vectorworks 2022 C:\Users\All Users\Nemetschek C:\Users\Bill\AppData\Local\Temp\Nemetschek C:\Users\Bill\AppData\Local\VirtualStore\Program Files\Vectorworks 2022 C:\Users\Bill\AppData\Roaming\Nemetschek I am assuming that there are some words missing from that "backup" paragraph. Question: How would you rewrite those two sentences and how would you clarify what folder/directories should be backed up? Thank you.
2022 Sections: in Fundamentals vs Architect vs Design Suite
Bill replied to Bill's topic in Architecture
Thanks for the good news. The reason I thought that Architect didn't support Sections was: https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_sections.htm Cutting sections In the Vectorworks Fundamentals workspace, the cutting section commands define ... and Creating section viewports (Vectorworks Design Suite required) https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_2D_sections.htm the Cut 2D Section command (Vectorworks Fundamentals workspace only) https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_3D_sections.htm From the Vectorworks Fundamentals workspace, the Cut 3D Section command Thank You -
Hi, I am experimenting with the 2022 trial version. After looking at the Help, am I correct that: 2D & 3D Sections are only available in the lower priced Fundamentals version Section Viewports are only available in the higher priced Design Suite version? I.e. with the mid priced Architect version I cannot create a section. Thanks, Bill
Is anyone successfully running Vectorworks v11 on Windows 7 or Windows 8?
Katie, I'm still using v11, and they are not menus, so this may not be valid. Joists In a brand new file I can insert a Joist using the Joist tool in the Objects palette. With nothing select, if I then click on the new joist, it takes a little over 3 seconds with my 2 ghz, 1 meg of memory, Windoze 2000 PC, for the Object Info Palette (OIP) to show the info for the joist. If I create two or more joists, it takes that 3 seconds for OIP to show the info for the first joist that I click on. If I then click on another joist, the OIP is updated instantaneously. Maybe what is happening here is that the Joist plug-in is loaded from disk and translated to some "excutable code" and that is causing the time lag. But when you click on something other than a Joist, VW throws the translated version of the plug-in away, only having to "re-translate" it the next time you click on a joist. Classes I have one drawing with about 180 classes. When I try to view that list via Organize, Classes, it takes about three seconds for the the window to be displayed. This is something that is super simple to do, just showing data that is sitting somewhere in memory. But, Organize, Classes Visibilities, is instantaneous and so is its sorting. Sorting is more complicated than just displaying a list of classes, as in the nornmal old classes, list that I mentioned above, where you can edit a class. And now having said that, I think that it is redundant to have both of those "Classes" choices in the Organize menu. The sorting capabilities in the "Classes Visibilities" list should be part of the normal "Classes" window, and likewise for Layers.
Kevin, Thanks for the idea. It makes sense. Regarding this forum's software, I think you will get used to it. Most of the ones I visit are like this and I am used to them. The others seem to be of an older style, older technology, and less user friendly, too me at least.
Looking at the Title Block created for a ConDoc. It contains two circles with lines going through their centers horizontally and vertically. What are those cirlces used for?
Katie, It is astounding how Vectorworks lets me use the flyover tool while rendered in Open GL. There are a ton of calculations that take place for every single thing in the drawing. And all of this happens fast, for me with a 2.0 Ghz, 1 mb PC. The code that nmakes that happen is probably written in C or some other compiled language. Maybe starting with V10, I too noticed some things that are comparatively much simpler than the flyover tool, yet taking more time that I thot necessary. In Ben's case, something like a drop down menu should almost finish before it starts. I'm guessing that some things in Vectorworks are not implemented in C, but use VectorScript. VectorScript isn't compiled, it is interpreted/translated, like having someone translate from English to French. The time to communicate increases. Is it possible that some things are being implemented in VectorScript?
Board Plug-in: rotated objects mysteriousl rotated back
Bill replied to Bill's topic in General Discussion
Short story Objects created via the board plug-in and then rotated 90 degrees around the x or y axis are sometimes mysteriously being rotated back 90 degrees by the time I open the file to do more editing. Long story I am using the board plug-in to create the pieces/objects for a frame and paneled box. For the side pieces of the box I create the board and then rotate it 90 degrees around the appropriate axis to make the board stand up. I have side pieces for the top/lid of the box and the bottom. Periodically, the top or bottom side pieces will fall over. I don't think they have both done it at the same time. Thinking I might be accidentally doing something I fixed everything then duplicated the top twice and moved each dupe to a separate layer. The only difference between the copies in the separate layers was that for one of the layers all the pieces were in a group, which is the way they were in the original working layer. Today when I opened the file, all three versions of the top had their side pieces fall over. I'm save multiple copies of the drawing plus exporting it as a vectorscript with the hope that when it happens again, maybe I will see something in the vectorscript file. Question Anyone else seeing any wierd behavior with the rotated board plug-in objects? My guess is that, randomly, the information that indicates that the board has been rotated around an axis is being lost when the file is saved or is not being used when the file is opened. -
Ramond, I tried the root volume shortcut idea. In windoze terminology I open "My Computer" and opened another window and navigated to the VW folder. Then I dragged by d-drive as a short cut to the VW folder. I first tried this as the include but it gave me my original error: code: {$INCLUDE D:\wff\vw\Scripts\EraseBanana.vss}[/code][/indent] Then I decided to look at the file name of the actual link. This is the file that it created in the VW folder: code: Data Disk 1 (D).lnk[/code][/indent] And this wierd looking VectorScript include worked: code: {$INCLUDE Data Disk 1 (D)\wff\vw\Scripts\EraseBanana.vss}[/code][/indent] I then renamed the long d-drive lnk file to: code: d.lnk[/code][/indent] And this include worked: code: {$INCLUDE d\wff\vw\Scripts\EraseBanana.vss}[/code][/indent] Thanks for the interesting tip.
Raymond, Test 1: using "D:" If you literally meant to use "D:\..." I don't know how to get that to work, i.e. use a ":". Since this worked: {$INCLUDE d\wff\vw\Scripts\EraseBanana.vss}, I thought that I just needed to copy "d.lnk" to "d:.lnk". But, that put the file named ".lnk" on my d-drive. Trying to rename it resulted in a DOS syntax error. (I'm playing around in a command prompt window). With this shortcut file: code: C:\Program Files\VectorWorks 11.5.0\Plug-Ins\d.lnk[/code][/indent] I got the error on this include: code: {$INCLUDE d\wff\vw\Scripts\EraseBanana.vss}[/code][/indent] I copied d.lnk up to the VW folder and it worked. Test 2: Using the Plug-ins folder To make things a little simpler I put a script with this name in the Plug-Ins folder: FakePlugin.vss. I.e. no short cuts involved. This include gave that same error: code: {$INCLUDE FakePlugin.vss}[/code][/indent] But, if I moved it up to the main VW folder the that same include worked. If I moved the file back to Plug-Ins, this include did work because plug-ins is in the main VW folder: code: {$INCLUDE plug-ins\FakePlugin.vss}[/code][/indent] Therefore , I think that VectorScript includes have a bug and only allow you to include from the main Vectorworks folder. If you want me to try anything else for you, let me know.
Raymond, I'm sort of glad you are having the same problem on the Mac, at least I'm not crazy. I experimented with your hint about the shortcuts (links, aliases). I was able to put a shortcut, in the VW program folder (c:\Program Files\VectorWorks 11.5.0), to my script on another disk. This is the file name of the sortcut created by windoze: code: IncludeErrorFromLnk.vss.lnk[/code][/indent] This include worked: code: {$INCLUDE IncludeErrorFromLnk.vss}[/code][/indent] I also put a shortcut, in the VW program folder, to another folder, not just a file. That folder was also on another disk. This is its folder name: code: IncludeError.lnk[/code][/indent] I was then able to include scripts from the folder: code: {$INCLUDE IncludeError\IncludeError.vss}[/code][/indent] I submitted a bug report on 4/29 to vs_support@nemetschek.net. No response yet. Thanks for the tip.
