FunctionTony
    2
Everything posted by FunctionTony
  1. It seems that in VW 2019, the Create Object input has been changed. 2018 Example: Double click Rectangle tool, Width is Highlighted, Directly input width dimension, Tab, Input height dimension, Enter, Click to Place object. 2019 Example: Double click Rectangle tool, Class is Highlighted, Have to Tab Two Times to highlight Width, Input width dimension, Tab Input height dimension, Enter, Enter, click to place object. Is this a change in the software or a changed setting? If it is a setting, where do I change this? If it is change, can it be changed back? Thank you.
  2. I use X Dimension on my plots to located fixtures on-site. But when I include the X dimension in a report (instrument schedule etc) the dimensions are unrecognizable (see attachment). Fixture 9 should read "-19'5" instead of "-1.941666666666652e001'" Is there a way to fix this? Thank you,
