Meschter
    1
Reputation
0 Neutral
Personal Information
  • Occupation
    Sound Designer
  • Homepage
    appliedaudio.tech
  • Location
    NYC
  1. Hi all - I have created a document that uses Text Along Path, to have the text wrap around this edge of a circle. This all looks good. I have changed the text a few times with no issues. However, now, when I try to change the wording I RightClick on the text and choose Edit Profile I get the edit window BUT the text appears only for a half second then disappears totally - BUT the Object info palette goes blank! ... I have Show/Snap/Modify Others turned on for classes and layers, so I don't think it is a visibility issue. Now, one thing it MIGHT be is that I have copied and pasted this Text Along Path object... could it not like to work on copies? I don't think that could be it because it HAS worked with some copies before. If I recreate the file from scratch it works and will work on copies but at some point along the way it just stops allowing me to edit this text What am I missing? Thanks in advance for your help, Dave I am using VW2017, Spotlight on PC in Windows10
