Zenlux
    9
Everything posted by Zenlux
  1. No. Failed. That wasn't what I was looking for. I believe your solution was to do one list of objects for each area. This is not what I was looking for. Let's try again with another type of an example. I have different areas and their amount is changing all the time. The worksheet report should anyhow print out all the furniture in all active areas without me doing new records all the time. So - can I do one single worksheet report for furniture that summarizes items that match two different fields on record? Or a field and a layer? Or any combination? I'm trying to automate the following: Area1 Chair1 1pcs Area1 Chair1 1pcs Area2 Chair1 1pcs Area2 Chair1 1pcs Area2 Table1 1pcs Area2 Table1 1pcs into-> Area1 Chair1 2pcs Area2 Chair1 2pcs Area2 Table1 2pcs
  2. Hi, Does anyone know if it's possible to sum items that match two fields in worksheets? I need to sum all items by type and by layer so I can get counts for chairs on area X and chairs on area Y on different rows of the same furniture report.
  3. Right. New feature without the quotation marks. Thanks Mike. Tried it and it works quite well! - Miika
  4. Hi all, Now that I upgraded to 2019 I cannot copy/paste from 2D symbol component to 3D edit space. Is it just me or is this new "feature"? If I copy 2D and go to 3D edit mode and paste, the pasted polygons are pasted to 2D side doubling the polygons there. I use paste in place. In case anyone's wondering why the hell this Finn is trying to do that let me answer. For positioning. In earlier versions I always adjusted the positions of 2D and 3D to match. Now I don't know how should I do it. - Miika Riikonen
  5. HA! Got it! Using the 'Use at creation' tick box on class properties I was able to use the class markers and alter their sizes as well. If the cable was created without using the 'use at creation' tick I wouldn't know how to scale the markers.
  6. Hi, Could someone tell how I could scale the start point circle and the end point arrow on cable tool? I'm drawing using 1:500 layer scale and they are blocking a great deal of other info like a half a meter truss. vw2018 sp2
  7. Thank you for your input. Using horizontal truss as 3d only and rotating it did the trick.
  8. Hi all, Does anyone know how to remove the connection lines that seem to appear while drawing truss system? I don't.
