Mike Myers
    4
Reputation
2 Neutral
Personal Information
  • Occupation
    Freelance Programmer/ Production Electrician
  • Location
    Honolulu, HI
Recent Profile Visitors
  1. I agree completely. Once the cable is associated with the fixture it will make life so much easier. Without it being associated to the fixture there's not much point on me doing all the clicking around that this tool requires. I posted this to the wishlist two years ago but unfortunately it hasn't materialized yet...
  2. Thanks for the response. Can't wait to see it in action!
  3. There should be a way for the cable tools to drop the info for a jumper into it's associated fixture. For example, if I am using the "Assign Multicable Circuits" tool it is already assigning circuit name, circuit number, as well as dropping a cable into the drawing based on your settings. There currently is no setting or way to have that cable input into a field in the fixture. So in addition to assigning circuit name and number it would also put "5' L6-20" into a "Jumper" field or "10' 5pin DMX" into a "Data" field. This would allow cable fields to be exported to Lightwright 6 which I think would make managing the cable info created in Vectorworks much easier.
  4. I've been playing with the new cable tools in VW2017. I am wondering if there is any way for the tools to drop the info for whatever jumper into it's associated fixture. For example, if I am using the "Assign Multicable Circuits" tool it is assigning circuit name, circuit number, as well as dropping a cable into the drawing based on your settings. Is there a setting or way to have that cable input into a field in the fixture. So in addition to assigning circuit name and number it would also put "5' L6-20" into a "Jumper" field or "10' 5pin DMX" into a "Data" field. Is this something that already exists or can be done within the current version? This would allow cable fields to be exported to Lightwright 6 which I think would make managing the cable info created in Vectorworks much easier.
