Ralph P
    10
Everything posted by Ralph P
  1. Solved! I actually remapped the Sketch command to be Create Section Viewport, since I never use the former, and frequently use the latter. I wonder if it bugged out and still pushed through the Sketch command...weird. Thank you so much!
  2. Hi all, Random sheet layers in my file have a strange bug where lines will appear broken/curvy. It only seems to affect layers at random, no idea why. When I pan around with the mouse wheel, they appear straight like this: But once I release the mouse wheel and things "buffer" for a second, they settle into looking like this: Any help would be greatly appreciated! Best, Ralph
  3. In case anyone was wondering... I finally got around to updating to SP2 - issue resolved! It was listed in the changelog for the update too: "VB-111054 Display of Dashed Hidden Line sheet layer viewports is inaccurate"
  4. Awesome, I will give this a shot tomorrow morning, currently at my end of day work push!
  5. Then it must be something in my settings, since you opening my file would open it with your native Vectorworks settings, yes?
  6. Attached it. Copied and pasted the build into a clean file though, problem still persists - I think sending you my full working file violates some company client privacy clause. If you absolutely need the original, let me know. Problem Object.vwx
  7. Updated to SP1 and unfortunately it didn't help
  8. Updating shortly - getting my office admin to approve the install. All pieces are separate extrude objects. Smoothing angle is set to the default at 1.00 deg.
  9. Vectorworks 2017 (Build 327801) on Windows 7 Professional 64-bit. Should have provided that, my bad - first post!
  10. Hi, I've drawn a 3D structure (image 1) and created a Top view viewport on a sheet layer. In both the design and sheet layers, when the object is oriented vertically, setting background render to dashed hidden line works fine (images 2 and 3). But when I rotate it 90 degrees, like I need it to be in my sheet layer for the construction drawing, the dashed hidden lines become incomplete (pictures 4 and 5). What's the issue here? Thanks in advance!
