BG
    390
Posts posted by BG
  1. I would like to know how people set up there framing / ceiling foundation plans etc. The layer linking off the "base plan" from which to draw over seems to be one method. but the control of the line type from the linked plan is impossible?. For example in a "floor framing plan" how does one show the walls under as dashed so as to make the framing layout over clearly represented. I am also aware of "greying" out classes layers etc.. but this is unsatisfactory for copying and reproduction.
    Any ideas would be much appreciated smile.gif" border="0
  2. Katie, I forgot to mention this is an intermittent problem that doesn't occur in all files. The files start out printing rotated text fine only to have this problem occur during the drawing process.
    Would you mind if I sent you the file to look at?
    Brett
  3. If a dimension value is manually entered (ie "show dimension value" has been un-checked) it would be great to have an option to have VW revert the dimension value back to it's default value if the dimension line is changed. This would reduce the possibility of having incorrect dimension values showing after objects are modified.
