BG
    391
Posts posted by BG
  1. Paolo, The rotated rectangle problem has always been there since we have used VW, which is quite some time, and it still frustrates us.
    BG
    And not being able to rotate the drawing axis is also a frustration that we live with.
  2. We are also experiencing random crashes like the ones mentioned above and the screen redraw rate seems to be around 3 times slower than 11.0.1.
    What is the best way to revert back to 11.0.1 on a XP computer?
    Thanks
    BG
    WinXP Pro VW11.5
  3. When opening drawings saved in VW 11.5 format using VW11, a message appears saying that the class visibility has been changed on some viewports and to see these changes look at a text file located in the program folder.
    Why is this occuring? Very frustrating having to locate these changes and correct them.
    Thanks
    BG
  4. When opening drawings saved in VW 11.5 format using VW11, a message appears saying that the class visibility has been changed on some viewports and to see these changes look at a text file located in the program folder.
    BG
  5. Hi Katie & others
    Jonathan's movie shows exactly what the 2D reshape tool should be able to do. But it doesn't work like Jonathan shows. The drawing label does not move even though it is fully enclosed within the marque. Jonathan must be using a drawing label symbol or something.
    BG
  6. Hi Katie
    No help required thanks. It shouldn't matter what the VW definition is, if it is a 2D object is should move.
    I will add this to the wishlist. It makes sense to me that the 2D reshape tool would be "better" if it did move all 2D objects including PIO's, reference markers, labels etc.
    Regards
    BG
  7. Hi Travis
    Yes I understand what the 2D reshape tool does, but why can it not move all 2d items? When say you are extending the length of something using the marque, everything extends/moves including dims, text, groups but not PIO's. I cannot think of a reason why these should not be included? They are 2D items. It's a hassle having to manually move these items after resizing the drawing.
    BG
  8. 2 messages while printing drawings (8 different sheets in the same file), using FILE, PRINT
    first message ?vectorworks has detected a condition of instability?. Save and quit vectorworks?
    second message a minute later ?Vectorworks will shortly be unable to continue functioning. Please save your work and quit immediately to avoid loss of work?
    Any ideas how to prevent these messages happening?
    VWA11.0.1
    G4MacOS10.2.6
    768 MB RAM
  9. 2 messages while printing drawings (8 different sheets in the same file), using FILE, PRINT
    VWA11.0.1
    G4MacOS10.2.6
    768 MB RAM
