Mbyrne
    4
Reputation
1 Neutral
Personal Information
  • Occupation
    General Contractor - Production Services
  • Homepage
    www.byrneproductionservices.com
  • Location
    Canada
Recent Profile Visitors
  1. This post saved a ton of issues I was having. Thank you!
  2. Thanks Andrew. I managed a work around by setting the lens calculation as needed on the Screen Plug in Object, then turning off the "display Projector" option. Then inserted a symbol for the actual projector. I then aligned the locus point of the lens edge wiht the projection cone to get it to line up properly.
  3. Hi All, I am having an issue where the lens information on an inserted projector will not diplay properly. Essentially I am adding a projector that is ~22 feet away from the screen. Screen is 13'6" x 24' standard fast fold. If I select "place projector by distance" It diplays the incorrect (and Non existent) lens value. If I select the lens that I want to use (.80) then the projector does not realistically sit on the truss position it needs to. Has Anyone else figured out how you can override this default?
  4. I am having an issue with VW 2016 during start up. When I open VW it grinds to a dead halt at the "Initializing Workspace Support System..." Stays there for 10 minutes, then very slow performance once it finally opens. I am on Windows 7 PC 16G RAM quad core i7 processors 64 bit Help please
