Dill
    7
Everything posted by Dill
  1. Thank you guys, my issue is, that Thank you guys, it seams the only solution is to change the orientation of the Symbol itself. The facing direction option might help in the simplest setup, but at little more complex ones like with shiftet rows or even different H and V distances between seats and rows, it would interfere.
  2. Sorry, what I meant wasn't the distance between the rows, but the offset of the chairs between rows. In the seating section settings you can set the 'Alignment Type' ● Shift Rows: seats are aligned with the boundary ● Align Rows: seats in each row are aligned directly behind one another ● Offset Rows: every other row is offset by half the width of the first seat ● Distribute Rows: seats fill the boundary edge-to-edge; spacing is adjusted to distribute seats evenly in each row, with Seat Spacing treated as the minimum value I want to have it on 'Offset Rows' wich means that a chair is offset a half position (to the left or right)to the chair in the row in front of it. This is wanted to have the audience looking through the gap in between the two people in the next row in front of them. Like it often is done in Theaters or the movies. This works fine for the standard situation. But for Covid limits where the distance between seats is much larger, it doesn't work anymore. What i get is this: What i would like to have is this...
  3. I try to use the seeting assistant with a costum chair 2D/3D symbol. But it seems to be in a wrong orientation, as it is turned 90° to what it is supposed to. Is it possible to change the symbols orientation easily, without rotating both element (2D/3D), in the symbol editor?
  4. Is there a possibility to change the row shifting in the seating section assistant? It seems, it calculates the shifting by the symbols width only. But if there is a different distance set between seats, it doesn't change the shift as to have it in the middle of the neighbour seat rows.
  5. Hello, I do have an issue with tilting a screen. If I use the tilt option in the OIP, only the projector is tilted, but the screen stays put. How can I tilt the projection screen? see screenshot: https://ibb.co/7YShzMq
