182 -
Posts posted by Paolo
I'm trying to do a script that starting for a selected polygon, given a step parameter, a bevel ray and an extrusion value, create a 3D object corresponding at the original polygon extruded beveled with the corrisponding ray.
The idea is to use the tapered extrusion for each step, changing the height and the angle values.
I've started this project but I found some obstacles to go on.
Is anybody interested in a collaboration to realize this? If yes, contact me to share ideas and code. Thank you.
VW9 performance slower than VW8.5 on boolean operations between solids
in Vectorscript
Posted
Hello, I'm Paolo from Italy,
Using VW9 I realized that boolean operations between solids are very much worse than VW8.5.The evidence jump to eyes using boolean subtraction when one of the solids involved contains round parts (ovals or round rect) and is obtained by multiple extrusion.
Perform the following test in VW8.5 and VW9.0-------------------procedure test;varbody, hole, edge, difference : HANDLE;result : INTEGER;chrono : LONGINT;
beginchrono := GetTickCount;beginXtrd(0,10); RRECT(-20,20,20,-20,14,14);endXtrd;body := LNewObj;Move3DObj(body,0,0,-1);
beginXtrd(2,10); RRECT(-18,18,18,-18,12,12);endXtrd;hole := LNewObj;
beginMXtrd(2,0); RRECT(-18,18,18,-18,12,12); RRECT(-16,16,16,-16,10,10);endMXtrd;edge := LNewObj;
result := SubtractSolid(body, hole, difference);result := SubtractSolid(difference, edge, difference);
chrono := GetTickCount-chrono;message(chrono,' /60 equivalent to ', chrono/60, 'seconds');end;
run (test); -----------------
test results on my computer are:with VW8.5: 6/60 equivalent to 0.1 secondswith VW 9 : 970/60 equivalent to 16.16 seconds!!!
The test has been performed on a PowerMac G4 533 MHz, 384Mb phisical RAM, 576Mb virtual RAM122.880 Kb memory assigned to VW8.5160.000 Kb memory assigned to VW9
Both programs have 3D conversion resolution set to minimal in the general preference panel. (Obviously higher 3D resolution means test time increasing).
I'll be glad to know why in VW9 this simple operation is incredibly slower.Please, let me know if the test has similar results on your machines and help me to find out a way out. Thanks Paolo Marcuccetti
ARCO ARREDAMENTI srl55049 VIAREGGIO (LU) - ITALY - Via Aurelia Nord, 102tel. +39 0584 46465 - fax +39 0584 46466internet: http://www.arcoarredamenti.it - e-mail: info@arcoarredamenti.it
