589 -
Posts posted by JMR
Is it possible to do math with data tags?
Example:
A Data tag reads the door rough opening width 1100.
The number 1100 is divided by 100, leaving 11. Letter M is added, thus final text on the tag would be "11M“.
This is just one example, I can think of many others uses as well.
I agree. The surface hatch controls are mentally complicated and simply do not work properly. Impossible to get hatches to align with others.
This method can be used to create walls of eg. historical buildings so that they remain editable, btw.
Wow...since wall hole functionality is used here, I take it that walls remain wall objects? They are not converted to generic solids etc.?
Ok the video answered my question. Excellent.
Converting a tile to an ordinary hatch would be great, too. Tiles won't show up in exported DWGs, hatches do.
These arrowheads sometimes appear with the ceiling grid tool, too. However the attribute palette is in correct state at creation and the arrowheads can be removed with it.
Excellent, we'll try that. Thanks!
BTW to avoid these kind of situations it would be very helpful if the symbols had the option to inherit the visual attributes of the parent class...
Thanks, the problem with that is that the "wrong" classes the symbols reside on, have also legitimate other objects.
Hi all.
We have set up multiple symbols. Each of these have one particular symbol nested within. It turns out that some of these reside in a wrong class.
Custom selection/modification isn't able to select symbols from within symbols. As far as I'm aware.
Is there some other way to batch-change the classes of these nested symbols?
The contents of the nested symbol itself are ok.
Thanks
To elaborate further on the correctedness of the window (or any) object - there is no option for an architect to produce a drawing that is wrong, or "almost right". Construction drawings need to be perfect. Otherwise one might get a hefty bill from the client. This is something that people in some other industries don't always get. Even some architects who have not run an office of their own don't get this. You really do get in trouble for erroneous drawings. An accidental mouse scroll in an Autocad paperspace viewport is a prime example, cost one practice about USD 50 000 due to wrong scale (yes there are ways and clauses to avoid these, but still).
A presentation can be schematic, but the information it conveys must be correct and there must be no room for any misunderstandings.
- 2
4 minutes ago, _c_ said:
We need user defined geometry that can be parametrised, so everybody can do a door and and window as they want it to be
Along the same lines, there was some discussion earlier about extrusion-based window geometry and profiles in general:
Details of almost anything can be obtained from the manufacturer, these parametrised via extrusions etc. might be one way forward. However I'd take any improvements, even incremental ones. As long as there would be some signs of life.
Currently the end result is way too far off the real built window. And there is no time to custom-model each different window considering the economic constraints of an architect's practice.
Anyone else seeing this:
After SP5, saved views sometimes won't activate any saved views. Redefining the view remedies the situation.
Eg. for our Synology DS 1517+ NAS server I guess I need to install this package(?):
https://www.synology.com/en-global/dsm/packages/Docker
- 2
7 hours ago, line-weight said:
One of the most baffling things to me is the situation with the door/window tools - we know there are plugins available in certain countries that are better than the stock tools
This. For an architect, doors and windows are THE most important plug-in tools! Not some silly photographs-to-choppy-3d-geometry tool, while maybe a fun curiosity. Yeah I can model a star shaped window if I like but that's not a productive and easily adjustable workflow. My buildings have hundreds of windows. I just need to get enough of the geometry right with the stock tool, which currently creates weird solid sills like I have never seen anywhere in real life... 🙄
- 4
This would be a very handy option. AFAIK not yet possible?
It would be a breeze to capture a color chart image and then sample that in vectorworks for solid fill etc.
On 9/11/2020 at 1:54 PM, MartinBlomberg said:
Hi, thanks for the reply!
It's already set on "Low" actually.
I can try the symbol change, but that doesn't cut it when I'm about to present it to the client.
And I want to be able to make adjustments with the original chairs present.
Using a simple box etc. for chair geometry can help diagnose the reason for the slowness.
If the culprit indeed is the chair geometry, you can set up views and renders with that faster geometry present and change the symbol to the final, proper chair before issuing and rendering to the client. While not exactly what you want, at least you can work faster.
If simplifying the chair geometry does not help at all, then the reason for the slowness is somewhere else.
- 1
Sure, the file size is a bit large sometimes though. No way to prevent retyping...
Hi all,
I wonder if it would be possible to include text copy-paste protection options in the pdf export settings.
Currently I can do this eg. in Nitro, but is has to be done manually, for each file separately.
Sometimes it's necessary to protect one's intellectual property. The need is very much dependent on to whom the pdf is circulated to. Usually it's not necessary, but it would be a nice option to have.
Data tags and mathematical operations?
in General Discussion
Posted
Excellent, thank you! This is very good news indeed.
In this case it's about the local door size denotation standards, the so called "modules" =M =100mm.
