3,755 -
Posts posted by line-weight
(And no I can't stomach the switch out of the cult at the moment!)
Yes, I'm aware of the warranty issue. Up to a point it's a risk I'm happy to take knowingly. I've done so on all the mac minis I've owned over the years, all of which bought secondhand when 2-3 years old and I've not had any problems. That said, the investment in a mac pro would be more substantial - but there are secondhand outlets which offer a 1 year warranty.
I could argue that even if I buy "new" mac pro it would be a model released at the end of '13. So buying a model from 2012 doesn't seem hugely different.
Looking to get a new computer.
For some time I've been a big fan of the mac mini - affordable, and seems to work fine for mainly 2D stuff. Plus, relatively easy to upgrade because I can keep my screens, keyboard etc and sell the old mini on ebay - or indeed do semi-unofficial component upgrades.
Now I need something a bit more serious as I move into doing more 3d stuff. My options, if buying new, seem to be an Imac (upper end of the range to get the recommended video cards) or a Mac Pro (it looks like the lowest-end one would do me fine).
But I'm not entirely keen on the iMac because it can't be upgraded and I've already got screens. And the Mac Pro would be very nice but of course expensive and probably overkill.
So I'm starting to think about getting a second hand Mac Pro. Maybe the mid 2010 or mid 2012.
My question is essentially... how future-proof will that be - especially with regards to VW? Will I get left behind in a couple of years when my computer is essentially 5 years old? Or is it reasonable to expect that they could hang on a bit perhaps with some component upgrades?
I think I might have worked out how to fix this, at least in some situations.
It seems that if you have several viewports on a sheet, even if some of them don't have a drawing number label, VW has assigned them a number anyway. So, say you have 6 viewports, and you have one labelled "1" but no labels attached to the others.
You are then trying to label one of the others "2" but VW is telling you that number's already in use.
I think this is because it thinks one of the un-labelled viewports is no. 2. It may also think that all the other viewports have a number as well.
So I think you can sort it out like this -
apply high-number labels to all those viewports...say, number them 10,11,12,13 and 14. Now they have a label sequence that doesn't cause VW conflicts, and the number 2,3,4,5 and 6 slots are free.
I *think* it generally then works to go back and re-number those viewports with the sequence you want.
Thanks, glad I wasn't missing some obvious setting at least!
Too bad there isn't a way to simply display a range of cells in a particular instance of a worksheet. For example, you could set a placed worksheet to display rows 1-60, another 61-120, etc.
For now, I've placed the worksheet on a Design Layer with a Sheet Layer viewport cropped to the rows I want to display. It sort of works, but if the row heights change at all (from adding an entry that wraps to a new line) then I get a row half cut off.
This is how I've been dealing with this situation.
I thought, this is messy - must learn how to do this properly...there must be a way of doing this - at least, maybe in the latest release even if not in VW2011 (which I'm using at present).
So a bit of searching brought up this thread - and the answer seems to be, no, there is no tidy way of doing this, even in the latest, supposedly BIM-tastic version of VW.
Is it unreasonable to feel this is a pretty basic capability to be missing?
If I'm trying to move towards a way of working where as much info as possible is contained within the drawing and associated databases, this kind of thing really saps any faith that sticking with Vectorworks is going to make this easy.
I can create databases and spreadsheets...but only up to a size that will fit on whatever printed page area I happen to be using? Unless I want to mess around with cropped views which as tsw points out above, are liable to go awry whenever extra rows are added. Really?
When I start a new project I tend to re-use a file from a previous one, deleting the project-specific info but retaining the basic layer/class set-up etc. It's a lazy alternative to setting up a fresh template file.
So this issue could be related to a problem in the drawing file that gets copied over each time. Thinking about it, the drawing file I'm currently using would have originated when I was using VW2008.
It's not really an option to rebuild the current file. But I suppose I should think about making a template from scratch for future projects.
Any suggestions about how to fix it in my current file would be welcome though.
Thanks JimW and no, you're not looking at the wrong thing.
I did the same as you describe in a new file and everything worked fine.
I use a custom sheet border and titleblock so tried again, using these, but again there were no problems.
So I don't know why it seems to be a problem in the file I'm currently working on. But I've had the same issue in other drawing files too.
Interesting.
If it really works, it would be great - free users up from investing in computing power.
It would mean that you couldn't do any work whenever the internet's down - which makes me feel a bit uneasy, but perhaps the cost saved on computer hardware could be invested into paying for a fast reliable cable service.
Agree with comments above that VW needs to provide much more in the way of detailed tutorials.
I think that video tutorials are easier to follow than written ones. Following a written tutorial can be quite painful (especially when they contain mistakes as I have found in past VW tutorials). Watching someone do stuff on screen is a much more efficient way to learn.
*thread resurrection
I see that Revit is still not available natively for mac ... however it is available "in the cloud" supported for mac users.
http://architosh.com/2015/12/autodesk-and-frame-just-put-revit-on-the-mac-officially/
Has anyone tried it?
I'm guessing that working on complex 3d models is going to be a bit laggy if everything has to happen over an internet connection. Or is that not necessarily true?
This is a problem I regularly have, using automatic drawing co-ordination.
I have a sheet with, say, 3 drawings on it. All is fine - the drawings are automatically labelled 1,2 and 3.
But then I want to add an extra drawing, between 1 and 2. So I want to renumber drawing "2" as "3", and "3" as "4", and then add in a new drawing "2".
It might let me renumber "3" as "4". But then when I try and renumber "2" as "3" I get an error message saying "That number is already used by a drawing on this sheet".
And I can't find a way to resolve this. I've tried deleting all the labels on that sheet, and re-applying them but the problem remains.
The only way I can get it to work is to create a completely new sheet, and then copy&paste the viewports back in, individually, in sequence, with new labels attached. This wastes quite a lot of time.
Is there something I'm missing here?
I'm on VW2011.
This is an old thread, and the Issue no longer exists.
For printing a grayed layer in a particular shade of gray, just set the gray level in the Print Dialog under "Gray level for grayed layers and classes".
This will not affect the gray level on-screen, but will lighten or darken it on the print.
Oh...I didn't realise the thread was so old! It came up in a search result and I didn't notice. Apologies.
My solution to this:
Instead of greying the layer in the viewport layer properties, leave its visibility as normal but reduce its opacity. You can control the darkness/lightness of the greying by adjusting the level of opacity.
We need a uniform classing system and ideally one that is set up in the software such that things are automatically classified as much as possible.
And this is another reason that using classes as a "workaround" solution within VW is not a sustainable solution in the long term.
For example - having class(es) into which you can put 3d objects that you don't want to see in plan view, because they don't render properly in 2D. That's not going to work once you're trying to share drawings using a uniform classing system that will allow models to display correctly regardless of the sotware package used to view/modify them.
Thanks very much for your comments Diamond.
I'll reply in more detail in due course...
I'm interested to know what people use when working in Vectorworks, both in 2D and 3D.
When working in 2D do you find that a graphics tablet with pen is better than working with a mouse? If so what size of tablet do you use, and how do you deal with multiple monitors if you use more than one screen?
Is it worth investing in a 3D mouse? Is it of any use when working in 2D?
3. One reason for architects not having a high level of design (LOD) is that we need to rely on other suppliers and consultants, and them achieving relevant code/standard requirements. How you document often relates to liability. Much of the information in our designs is for our own information and design, not a performance spec. If you watch Francois Levy's latest webinar at Novedge, he is extremely clear in pointing out, the BIM data he harvests is for his own information, and not as a performance guarantee. If the client wants that, they need to engage the relevant consultant. (http://www.novedge.com/webinar/178).
I've just had a watch of this webinar.
Near the beginning he mentions the various "myths" about BIM...quite a few of these matching some of my moans about the difficulties of using it in the real world.
For example the worry that we become constrained by standard components or what can or cannot be easily modelled in the software.
This concern is dismissed as a "myth" but the project examples don't convince me at all. The three projects shown simply reinforce my prejudices about what "BIM architecture" ends up looking like. I think other architects will know what I mean. Those projects don't have a high level of non-standard components. They don't involve irregular, historic existing structures. They don't have complex sections or spatial volumes or floorplans with multiple changes in level. You can see that it's pretty easy to break down the designs into floors, walls and roofs - in a convenient way for BIM classification. There aren't places where, for example, there's ambiguity about whether a certain element or portion of an element is a wall or a roof, or where a window isn't fully contained within a wall, say.
These are designs in which what are arguably really engineering considerations have had a heavy influence. There's nothing wrong with that in principle - I certainly welcome careful consideration being given to thermal performance, passive ventilation and so on. And if there are tools built into VW that make it easier to make intelligent design decisions about these concerns then that is great. But there's a whole lot of other stuff that is important in creating good architectural design that doesn't have much to do with tabulated databases. Software aimed at architects should be aimed at giving the architect more time and freedom to worry about good architectural design - not making it easier for the architect to do other people's jobs (I am thinking of the mention in the webinar about the ease of making a material takeoff for a contractor to submit his tender bid - that's his job not mine!).
Generating floorplans is such a fundamental part of architectural work that it seems rather unsatisfactory that we have to be using the kind of fiddly workarounds that digitalmechanics describes above.
Layered construction buildups (as in floors, walls and roofs) are also fairly fundamental to the way buildings are put together. The wall tool works ok (until you want to do something a bit unusual). But the workarounds for floors and roofs that digitalmechanics describes (using the tool for single layers rather than to generate whole buildup) should tell anyone designing these tools that they don't really work.
VW2016 promo videos tell me about Marionette and the ability to generate fancy facades through visual scripting.
But VW hasn't got good enough basic tools just for generating floorplans and sections from a 3D model! This is what they need to focus on first!
Col37400 – What parametric objects are you using at the moment? What are you struggling to get your head around that is preventing you transitioning to 3D?
In my "test" project where I'm trying out working properly in 3D so far I've used walls, doors, windows and stairs (and slabs).
If you have a look at this thread:
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=220561
it explains where I am finding issues with 3D. I have now managed to create a floorplan that I'm happy with - but to achieve that I've had to draw certain elements twice - in 3D (for the model only) and in 2D (for the floorplan only). And then switch on/off classes etc in different views.
So there's a way to make it work but it partly defeats the purpose of working from a 3D model - not having to draw everything twice.
It's questionable how much time this saves me from my previous workflow where I'd draw the plans (accurately) in VW and then have a rough-and-ready 3D drawn separately in Sketchup (it doesn't have to be as accurate because it was just for my own use in exploring options, and/or for presentation images).
In Sketchup, I can navigate and edit the 3D model much more fluently than in VW. This will change as I get more practiced in the VW 3D environment of course, but there are certain things that I can do in Sketchup that I just can't in VW. Admittedly I am using VW2011 and it seems that there are a few significant improvements I'd benefit from in moving to the most recent version. But when I look at the cost of upgrading (not just the software - I'd have to get a new computer too) I wonder if it's really worth it.
As I mentioned earlier in the thread, things like the cost of licences and hardware are perhaps not such a big deal to large commercial practices. But for small operators for me these costs are significant.
Yes. The floorplan is where most architectural designs are rooted. It's essential that users feel fully in control of how their floorplan looks and that information on the floorplan is "safe".
To make the move into 3D I don't want to have to start making workarounds to make sure that my floorplans still look right. I don't want to have to start using complicated classifications of objects so that some of them appear in 2D only, some of them in 3D only and some in both.
I want the software to give me lots of control over how the output looks, but once I've told it what I want, then it should worry about how the information is structured, leaving me to worry about the actual building designs instead.
This issue of how the output looks is very important to most architects. It's how we communicate (and indeed sell) our intentions to a variety of audiences. We produce different drawings for clients, for planning authorities, for builders. They use the same basic information but presented with different emphases. I feel in control of this working in 2D VW but not so much in 3D. As soon as I am in 3D I find myself thinking: this is the drawing which I want to produce - but I can't.
This is partly because I'm still making the transition. But I think it's true that there are drawings that I can produce using my established 2D methods (with help from, say, sketchup) which are simply not possible if I try and generate them from a 3D model in VW.
I wonder if VW needs to make more effort in understanding the needs of architects - working at all scales. Some of the features promoted in newer VW versions might be nice for people working on giant new-build projects but are completely irrelevant for me. Perhaps they need to take a close look at the way people working at the other end of the scale actually use VW, in order to understand properly what's actually important to them.
Another comment - apologies if I am going a little off topic here, but some might be aware of these products -
https://affinity.serif.com/en-gb/
Essentially these guys have built applications that aim to replace Adobe Photoshop and Illustrator. They are competing with long-established packages with vast functionality. They have managed to build something that has *most* of that functionality, but which is (a)more of a pleasure to use and (b)hugely more affordable. By pretty much starting from scratch they can throw out all the clunkiness of applications that have expanded in scope over many generations. And these applications are proving popular with people like me - small scale operations who can decide to move to a new package without worrying about retraining a large workforce, and for whom affordability is important.
I think VW could be in danger of losing previously loyal users in a similar way.
Some comments as a long-time (15 years) VW user who is trying to make the transition into working more in 3D, and generating information (in the form of sheets) from a 3D model.
I'm an architect. Mainly small jobs.
Digitalmechanics I have watched many of your youtube videos (and some of your posts here) with much interest. A lot of the issues they bring up are the ones that I see too.
The idea of ending the "tyrany of sheets" is very attractive. For me it's one of the most tedious aspects of the process. All the time spent working out how to most effectively convey the information necessary, and then trying to keep on top of managing it all when changes are made. The concept of having a central 3D model from which one generates plans, sections etc goes some of the way but the idea that one day the contractor builds directly from the model is very appealing (perhaps with a few caveats).
For Vectorworks to have their eye on that as a long term goal certainly makes sense. But from the point of view of a day-to-day user, I'd rather they focussed first on making the 3D modelling capabilities themselves adequate. My feeling is that we are only part way to the point where it's actually feasible to build one 3D model and then generate all the necessary info from that. There are still really, really basic things - like generating a decent floorplan for a roof space, or drawing non-vertical walls, for example - that need workarounds of some kind.
If I need to use workarounds, or add information in 2D, to produce a set of drawings that I can issue for construction there is absolutely no way I'd feel confident handing a 3D model over to a contractor to build from.
To me that should be the priority. Give me a VW which is flexible and sophisticated enough that I can build everything in 3D, so that I know that if I hand that 3D model over to someone else, any information they extract from it is reliable and complete. It feels we are still a long way off that.
Otherwise we find ourselves in a new kind of tyranny - one where we can only design buidings that can be drawn within the limitations of the modelling software. This has been a worry for me for some time - since I first tried a BIM type approach using Archicad many years ago. As soon as you want to introduce a non-standard component everything becomes a headache. It's what's made me stick to drawing in 2D (with 3D modelling in parallel for presentation purposes) up until now. Things have moved on enough that it seems now to make sense to work at least in a hybrid mode.
This is particularly relevant to those of us who design smaller and more bespoke projects - and supposedly we are one of the markets VW targets. Much of my work involves existing buidings and one-off designs. I don't want lots of parametric elements with settings that never quite cover what I need to generate. I want a 3D environment that lets me easily model things directly, and then incorporate into the main model in an intelligent way, so that when I generate a section or plan those things are rendered in a way that doesn't require further input from me to make things intelligible.
Over the past few years (like many) my approach has been to use Sketchup, alongside VW, for 3D visualisation. Sketchup was a brilliant piece of software engineering - it made working in 3D vastly more intuitive and enjoyable. Everyone else has been trying to catch up ever since. The 3D modelling environment in VW has improved quite a bit, but in some ways it still can't match my Sketchup version which is a couple of years old now.
Someone further up the thread mentioned the feeling that VW will soon "implode". I think I know what they mean. This is especially true for the experience of working in 3D. There are so many inconsistencies and too many operations that just aren't intuitive. Viewports within viewports. Dialogue boxes and duplicated tools everywhere. I gather the latest version actually allows you to dock tool pallettes - the fact that this is only being introduced in 2015 says it all, in a way!
So, I think the 3D environment in VW needs to learn to walk before it can run. Focus on making it an environment that is a pleasure to work in rather than a battle. I think it would benefit from a major overhaul, and soon.
I've been seriously considering whether Sketchup Pro would actually be a better tool for me to use. There's a lot of functionality I would lose by ditching VW but if I'm moving to a more 3D-centric workflow, perhaps I don't need it so much. I'd like to streamline my processes but so many aspects of VW seem the opposite of streamlined.
I know many will be very sceptical about the idea that you could produce construction documents from Sketchup (me included). For large scale projects it's no use but for stuff on the scale that I (and I think many other similar VW users) do - it's certainly food for thought, especially when you consider the relative cost of licences. Have a look, for example, at this series of videos:
Yes, something like that could work. Would still have to add in manually the bits of roofplane that you look down upon though. So perhaps include the roof in the top/plan viewport.
Buying an older Mac Pro for VW - false economy?
in General Discussion
Posted
Yes - I realise I was wrong about the iMac updates - I edited my post as you made yours I think.
And yes I've checked out the refurb options from Apple - one of the main options I'm considering.
