30 -
Reputation
0 NeutralPersonal Information
Homepage
www.devmatters.com
Location
London, UK
How to use & install scripts posted here
Neil's in... replied to Petri's question in Wishlist - Feature and Content Requests
This link is dead, is there an updated link? -
Hi all, I'm working with a roof face... I have made a window symbol as per usual to insert as a dormer. Two Issues: Floating invisible window some distance away from dormer. If you reduce the dormer width (closer to the window size) the dormer becomes asymmetric and the window is off centre. Pictured attached.
Leaded Lights / Leaded windows / Not Glazing bars
Neil's in... replied to Neil's in...'s topic in Rendering
Mitch Brooks the windows are all unique around the listed building, however the common denominator is the leaded windows which is the same everywhere. -
Hi all, current project we're working on has leaded lights (which in other countries may just be: leaded windows). I have tried to draw up the windows with glazing bars/muntins that are 2mm deep and 10mm wide (sorry imperial guys). Problems arise, when there is a top sash that isn't the same size the ratio of the bars comes out wrong. Basically it's a golden ratio arrangement. Therefore I thought in my wisdom to make a Renderworks Texture and assign that texture to the glass class for windows that use this, however, I've drawn up the leaded light template as an extruded object... I'm guessing this isn't possible to make into a texture. Can someone confirm this... otherwise explain how to do it. Many thanks!
Hi ray_isaacs that was it! Many thanks!
I've noticed this today, and not sure what it's called to be able to look it up and ultimately get rid of it... or at least do something about it if it's requiring something. It's the same border you get on a viewport when it needs updating, however I'm just panning round a white renderworks projection of my street-scape. Bottom half of my screen is occupied by this border. Advice what it is, what it means, and how to fix it would be much appreciated.
Hi JimW I repeatedly rebuilt this roof this morning and finally got round to getting it to rougly display! Firstly, The steps I had done to make it not work before: (while drawing is rotated in 2D) Draw the shape of the roof faces in plan over the floor below one by one convert each polygon into a roof face turn the flat roof in the middle into a floor and set the elevation to the correct z height grabbing a window from the Building Shell dump it down into an un-walled white space in the drawing, select convert to symbol (name it front dormer) delete symbol from drawing, set the opacity of the roof face down to a low value so I can see where the window needs to be inserted. drag from the resources browser the symbol of the window I want to use into and over the window I wish to create a dormer Turn roof surface back to 100% opacity. Select the dormer options and change it from gable to shed... boom!.... everything falls apart. Mostly the roof face disappears and dormer remains Re-click on dormer to change a setting, and press OK and both dormer and roof face are gone. Other observations during this are that once inserted the dormer and trying to select it, the fill and stroke attributes tool box will be flashing like an underground rave! (and usually between clicks is a high probability that VW may crash about 5 times). My solution: similar to above but the window I wish to insert I start with making the window tiny... far smaller than the one on the floor level, and once the window is a dormer, start editing the symbol settings, upping the dimensions to suit the one it is meant to be in the dormer. This makes the dormer more reliable and will not disappear. ~This ugly but makes the thing work~ Once done, re-create the roof face and reinsert.
JimW, did you have any luck with that file?
JimW I've emailed you the file, it's 15MB in size.
Hi JimW, We work off a file server (which for the time being is updating to windows 8.1 pro... and taking forever).. I'll be able to check as soon as that's done. We have had issues with file locking lately so it could be relating to that. Any advice on the dormer issue? Aside from starting again?
Hello all, I'm experiencing a once every 20 minute crash in Vectorworks Architect. Generally crashes when I hit save, or create a new class. The file which I've reset all plugins, purged all ... and updated plugin objects. I'm at my wit's end with this. Additional flaws in this project is in wireframe roof surfaces show dormers, in OpenGL they do not show, nor do they show in any renderworks mode. As you can imagine my week is ending on a foul note. I would appreciate anyone with a magic bullet for this, or even pointers to deal with stress! Many thanks
Wes, after much toying I succeeded somehow the floor levels was the answer which ultimately made it not display at all to display changing the wall from floor/floor above to slab/slab above... I'm now stumped with meeting this wall to a wall that does not have the string course and them displaying poorly. Due to it filletting non-string-course-wall to extents of string-course-wall Illustrated is what I'm getting both in rendered and in plan. It's not ideal as you can imagine,
Wes that's so obvious why did i overlook that? Many thanks! I'm having a bad day with walls today!
Hi there, I'm figuring I'll have to fudge this myself but how would you guys go about putting in a string/belt course a maisonry wall? The current detail acts as a sill to the windows on that elevation.
Sheet Border + Title Block (not updating)
Neil's in... replied to Neil's in...'s topic in Architecture
Hi there, I followed the documentation here: Creating a Custom Title Block in Vectorworks Fundamentals Is that something I've done wrong? Would you want to see my titleblock?
