173 -
Posts posted by cbaarch
comments based on 12.0 or 12.5
you should try using the Sheets Layers rather than views
to set up for printing and/or exporting to PDF
sheets export to dwg as paper space if required.
you can apply a non-associated hatch to an object
which allows rotation of a 2D hatch
(it actually creates a group)
not recommended for wholesale use, but good for a one off object
look for "applying hatches" in help
do you have VW Architect?
First
1. the installation was beta tested outside the NNA network
2. the instructions did say that if you want 12.1 to remain on your machine you needed to make a copy of 12.1 and update the copy
but all is not lost
reinstall 12 and update to 12.1
both 12 and 12.5 can coexist on the same computer
they use the same preferences
so such things as the recent files list are the same
try the following
create a group of the spaces
then paste in the second file - and ungroup
the spaces should then go to or, create classes found in the first file.
create the worksheet in a design layer
create a viewport of the worksheet
and place it on a sheet layer
scale the VP to fit whatever size to fit
and you can also crop the VP
i.e. if you only want certain columns or rows
also
duplicate the VP is you want Header
VP on a sheet layer can stack on top of each other
no more blank rectangles (-:
you have to "save as template" in order for the default
to be change
the extension for templates is .sta -stored in template folder
regular files are .mcd
for winxp versions
and if you are using cross platform
the file format for v9 and v12 are quite different
so when you open a version 9 file it actually converts it to version 12
so if you want it in version 9 you have to use Export
which means you will lose any "new" features in 12 that were not found in version 9
2 things
do not expect great colour quality from the 650
and make sure you can get cartridges and look at cost of cartridge and paper
and
charge colour plots to the clients
so service bureau cost should not be an issue
in the libraries folder the is a folder called Object Sampler
follow this path
vectorworks(folder)\libaries\object sampler\vectorworks basic\Vectorworks Architect Sampler.mcd
this is found on VW architect / WinXP installation
select all in the first file
Group the objects
copy and paste the group
your classes should be in the new file
delete the group
tested with 12.5
if you use Firefox get the colorzilla plug in
it will give the RGB values that you will need to create VW colours
then go to a Paint Manufacturers web site to get colour chips and run colorzilla over the colour to get RGB
if you create a new palette leave part of 1 column blank
then this becomes your custom colours so it will not mess up class colour assignments if you use that process.
in 12 and 12.5 there are found under libaries\object sampler\vectorworks basic folder
Just create a symbol of the border you want and place it
on the sheet layer.
for changing the info you can attach record to text
which is then available in the DATA tab of the symbol
have you checked to see if the class of the objects inside the symbol (which may be different then the layer/class the symbols was inserted)
are turned on in the VP
if you need to start over again
goo to My Computer - Tools - Folder Options - File Types
delete mcd
and it will ask you next time you try to open a file from the folder if you want to associate
and,
if you want to open the file with another version of VW
select the file
hold the Shift key - right click
and you will find "open with" option on the list.
the solution upgrade to 12.5
which can import pdf files
so just a matter of exporting pdf out of word
and putting them in the design layer so you can crop
them for larger sheets
this happens when the printer setting is not the same for all the sheets
just duplicate the symbol in the RB
and edit the new symbol from the RB
then place or replace in the design layer
you do nothing with these files
the setup program uses the info inside the files
to install VW
you can create a style with dual dimensions and use
the secondary dimension only
found under Dual View
the units for dual dimension show up as primary and secondary
which can be changed via Units
copy the whole 12.0 folder and rename to 12.5
then run the updater on the 12.5 folder
you can create custom dimensions styles
in 12.5 you can change the dimension style via the OI palette
and the dimensions can be on any class (changes are in preferences)
if you select a class to active only
the style for all dimensions can be change via OI palette when you select all
There are 2 ways to select Bold
the first one is how the font is designed
so you select the TTF that says bold - with Regular selected in VW
the second is to use Century Gothic and change the VW setting to Bold.
the latter maybe be "bold" enough.
Setting classes to 'nonprint'
in Troubleshooting
Posted
you need to set up sheets
then create Viewports
then in the OI palette you go to classes
turn off the class you do not want to see
then to go back and see it on screen
use a Saved view which can be accessed/created via
Navigation Palette if you have VW architect or Designer
