symo
107 -
Posts posted by symo
Hi There
Wanting to know if I can make everything default to the same line weight. Currently - when I import symbols (mostly lighting symbols in Spotlight) - the imported line weights can vary greatly. So without having the manually change the line weights in each symbol (really tedious) - the symbols look a mess on my sheet layer viewports - but cant tell until I print or publish the sheet layer. I like everything to be 0.18mm for printing.
I see that I can scale line weights in the advanced viewport settings - but I want all line weights to be the same.
Cheers
Symon
Well, thank you very much. That worked perfectly!
Hi there
I am wanting to create a drapewall with an angled top - so that it follows the roof of a marquee. Double-clicking on the drapewall only seems to let me alter the vertices on an XY plane.
How can I do this?
Cheers
Hi All
Having an issue when VW 2017 behaves very strangely when inserting lighting instruments when a plan is rotated (i.e a saved view).
Here are the issues:
- The default position is zero degrees in the unrotated orientation - so you need to rotate every fixture to insert it at zero degrees in the current view. Can this be overridden?
- When using the Align/Distribute Objects function to evenly space and align the instruments, i get unexpected results
- When I select the instrument with the plan rotated, I see the the outline of the the symbol in a zero degree orientation
Let me know if im missing something obvious of if there is a work-around
Cheers
You saved my life!
Many thanks.
Hi there
This issue has been driving me nuts. Some of the lighting symbols show their 3D position correctly whilst others do not.
In the attached VW2016 file, I have 3 different instruments - Selecon pacific 12/28, Selecon spx 19 and an ETC Source 4 19. Only the 12/28 shows the correct 3D position in a side or iso view. The others just point down.
They are all showing the correct lx position, at the correct height and set to focus point A.
Is it possible that the spx and source 4 symbols are faulty?? Is there a manual workaround for this??
Cheers
Using "plot & model view" and worksheets
in Entertainment
Posted
Hi all
I like to use the "plot & model view" command for showing vertical trusses with light fixtures in both lighting plots 3D renders. Problem is when I generate worksheets from the "create report" command, I get all the lighting instruments used in the "plot & model view" shown twice in the generated worksheets.
Is there a work around for this? I like to use worksheets for entering light data info.
