Dear VW friends,
I have been trying and failing at creating extruded text along a Helix Spiral, the text always seems to skew out
and leave the path. I tried playing around with the rotation around path but it's still turning out wonky... My goal is
to have the text extrude flat along the path so that it can placed on the outside of a cilinder. I feel its because the path is
rotating around itself slightly but can't figure out how to avoid this problem any thoughts?
I kept at it and I think I found a work around that gave me the result I needed....
The result is visually correct but it's hard to get it done in exact dimensions, so it took
me 4 tries to get it close to the size I needed... So maybe there is still a better way to approach this
but I did it as follows:
1. In top view I created a line (path) at an angle (the angle that worked for me was 7.5 degrees)
2. I used the text along path tool to extrude the text along the line (scaling height and width to match the length of the path)
3. Using a 3d locus I marked the center of the "text along path" object
4. In front view I then used the Deform tool to bend to object into a helix spiral using the 3D locus as starting point ( deforming 270 degrees was about the right amount for me)
I will post images of my process below... I still think it should be possible using the 'text along path" tool directly with a helix spiral path but just couldn't figure it out...
Thank you for your help!
p.s. I posted this earlier in the general forum not realizing it should probably have been here in the modeling thread.
