AJ Roslevich
    6
Everything posted by AJ Roslevich
  1. @jakez I was able to get VW2018 installed by following the instructions posted above. In case it's not clear, you have to extract the installer from the zip folder you downloaded, then find the file named "Vectorworks 20XX Installer" and extract that, as well. There are two levels of extraction. For the record, the computer I installed on is a Windows 8 PC, and I used 7-Zip for the extractions.
  2. My computer has one "Disk 0" which 4 partitions.... There's the Primary (C:), two Recovery partitions, and an EFI System partition. The "Type" for each says "Basic".
  3. Update: 1. Trying the installer again didn't work. 2. Downloading a fresh copy of the installer didn't work. 3. Extracting the installer with Windows Explorer instead of WinRAR didn't work. All three yielded the same result: a dialogue window saying "not enough disk space". If this helps, my computer is Windows 8.
  4. I haven't tried again recently, but I should have some time tomorrow. I will try again and report back.
  5. I can open my Vectorworks files just fine, and "Top/Plan" view is fine. But if I try to use any other view setting, I get the pop up message seen in the attached image: However, even with the render mode set to Wireframe, I still get this message. This only happens on VW 2015. VW 2014 works fine.
