tdunn
    3
Reputation
0 Neutral
Personal Information
  • Location
    USA
  1. @Ryan Nice writeup, I will likely direct others there for reference. I agree, at this point in time vectorscript is the only way to go if you value your data. Time to expand my skillset.
  2. Signatures require maintenance, as previously stated I am not a fan of I can see more info may be required. Current platform: VW 2012 SP4 (Build 162341) used for Spotlight, several current (all under two years old) Apple machines 10.7.4 I wrote some base code for OOo to take advantage of Spotlights xml dump for Lightwright but having to import/export is lame since theoretically ODBC is functional. I could use openxml and sql perhaps as a workaround but WTF its a released feature. I simply want confirmation from other users whether this is a bug so I can proceed thru higher channels with confidence or be guided from my ignorance. I can only assume it must be my error on my part as it would be very odd that this basic workflow is not in place in a professional application without the purchase of another very expensive application. thx
  3. I have connections between both VW2012-MySQL-OOoBase and VW2012-FMP12. It appears neither 'Update Database: Every record change' nor Object deletion are committed to the external DB rendering the feature high maintenance therefor not useful for my needs. Please confirm/deny and advise.
