Hippocode
    800
Posts posted by Hippocode
  1. The Descending and Ascending Sort function in the worksheet are nice but don't work properly on numbers placed in a text field.
    A lot of PIOS use a number to trace them, ideal to list them in a worksheet. Sadly, that number is stored as a string and won't sort properly
    Sorting will give the following:
    1
    10
    11
    2
    21
    22
    3
    4
    5
    6
    7
    8
    9
    Is there any way to sort them the right way and not tread them as if they were strings ??
  2. From what I know, each object has an asigned record where the data is stored.
    This way, in a database record we can retrieve data this way: objectname.fieldname
    This works for most fieldnames, but not for all. Is this because the fieldnames are language based so we need the real variable name ?
    If so, where do we get them ?
    For example Object space:
    space.length gives me the length of the space.
    space.'ceiling height' doesn't return anything
    Both length as ceiling height are parameters in the shape pallette of the object "space"..
  3. Forgot to mention -- just to make sure you're not reinventing the wheel, have you checked out the select similar tool?
    -Josh
    The select similar tool is different as it will select ALL possible symbols when clicking on one.
    The tool I made will only select the "kind" of symbols I select.
    If I want to change All my lights named L1, I just need to click one and the script will select all placed L1 symbols in the layer.
    Select similar tool would select all symbols instead.
    If not, i'm a fool. (edit: never noticed the tool properties could be changed. Thus i'm a fool lol, good practice though.)
    As a sidenote I ran into another problem.
    when trying to select the basic objects ( text, line ) the command doesn't respond, even if the string is right.
    t_temp:=concat(BNames[j]); {this returns Text}
    UprString(t_temp); {make it TEXT}
    test:=concat('T=',t_temp); {create T=TEXT to select all text objects}
    SelectObj((test)); {no text gets selected ?}
  4. Hey,
    I recently made a small plugin object trough the plug-in editor(Tools=>scripts=>vw plugin editor).
    Its ment to be a heat device drawn as a rectangle and some info in it.
    I've added it to my post, use it as a plug in object or look at the code of it to give you a heads up..
    PROCEDURE Radiator;
    VAR
    bc_ht,bc_wid,bc_height,bc_vermogen,i: REAL;
    bc_fontsize,keuzes,height,numberpos : INTEGER;
    objname,vermogen,bc_number: STRING;
    bc_textposition,bc_numberposition: CHAR;
    oh,rh,wh: HANDLE;
    result,hidetext,shownumber: BOOLEAN;
    BEGIN
    { retrieve custom object information }
    result:= GetCustomObjectInfo(objname,oh,rh,wh);
    { if object information was successfully retrieved }
    IF result THEN BEGIN
    { retrieve predefined parameter values }
    bc_ht := PRWIDTH;
    bc_wid := PRLENGTH;
    bc_height := PRHEIGHT;
    bc_vermogen := PVERMOGEN;
    bc_textposition := PSHOW_VERMOGEN;
    bc_numberposition := PSHOW_NUMBER;
    bc_fontsize := PFONTSIZE;
    bc_number := PNUMBER;
    vermogen:=concat(bc_vermogen,' W');
    { retrieve user-defined parameter values }
    { draw }
    i:=0";
    PushAttrs;
    FillPat(0);
    { draw rectangle with coordinates }
    Rect(0,bc_ht,bc_wid,0);
    { draw text }
    TextFont(GetFontID('Monaco'));
    TextSize(bc_fontsize);
    TextJust(2);
    hidetext :=true;
    shownumber :=true;
    CASE bc_textposition OF
    'O': height :=bc_ht+25;
    'I': height :=bc_ht;
    'H': hidetext :=false;
    OTHERWISE height :=bc_ht+25;
    END;
    IF hidetext THEN BEGIN
    TextOrigin(bc_wid/2,height);
    BeginText;
    vermogen
    EndText;
    END;
    CASE bc_numberposition OF
    'L': BEGIN numberpos :=3;height:=-5; END;
    'R': BEGIN numberpos :=1;
    height:=bc_wid+5;
    END;
    'H': shownumber :=false;
    OTHERWISE BEGIN numberpos :=3;
    height:=-5; END;
    END;
    IF shownumber THEN BEGIN
    TextJust(numberpos);
    TextOrigin(height,bc_ht);
    BeginText;
    bc_number
    EndText;
    END;
    PopAttrs;
    END;
    END;
    Run(Radiator);
  5. Hello,
    I've made a script to select ALL symbols in a layer, where atleast one of them is allready selected.
    I'd like to extend it for other objects(plugin, line, text etc) but I fail at getting the names of the selected objects.
    I know i'll have to change the selection part, but I just need to find a way to get the selected objects info
    PROCEDURE SelectObjects;
    VAR
    OCount,i,j: INTEGER;
    r, g, b :LONGINT;
    OName,OName2,OName3,strinkie,test,selectie :STRING;
    ONames : DYNARRAY[] of STRING;
    FUNCTION SelectThem(h :HANDLE) :BOOLEAN;
    BEGIN
    OName := GetSymName(h);
    IF OName ='' THEN BEGIN
    OName := GetName(h); {can't get the object name ?}
    END;
    ONames:=OName;
    i:=i+1;
    END;
    BEGIN
    selectie:='Geselecteerde symbolen: ';
    OCount:=NumSelectedObjects;
    IF OCount<2 THEN OCount:=2;
    i:=1;
    ALLOCATE ONames [1..OCount];
    ForEachObjectInLayer(SelectThem, 2, 0, 0);
    SortArray(ONames,OCount,1);
    DSelectAll;
    FOR j:=1 TO OCount DO BEGIN
    IF OName2<>ONames[j] THEN BEGIN
    strinkie:=concat(ONames[j]);
    OName2:=strinkie;
    SelectObj((S=strinkie));
    selectie:=concat(selectie,strinkie,', ');
    END;
    END;
    AlrtDialog(selectie);
    END;
    RUN(SelectObjects);
  6. Hey,
    I've been making my own objects and would like to have a custom list of choice in the object shape tab.
    This can be made by setting the parameter to "pop up" but I fail at getting the data from that popup into my vectorscript?
    Can anyone point me into the right direction ?
    I've noticed its not possible by doing variable :=PFIELDNAME;...
