Reedmac
    10
Reputation
0 Neutral
Personal Information
  • Occupation
    Project Manager
  • Location
    TN
  1. Any idea when that will be released? I didn't notice this until I did the last update and now it is very frustrating.
  2. Anyone else having problems with VWX 2018 loading? If I am not connected to the internet, it takes over 10min to load if it loads. Most the time it just freezes my computer and I have to force quit the program. I never had this problem with any of the previous version of VWX. This is very frustrating when you are on site or traveling and do not have internet but need to get work done. Is this happening to anyone else? I am also having the problem when I am online, just not as often as when my computer is not connected to the internet. Currently trying to open it on my laptop and connected to the internet. Had to force quit 3 times so far. Takes a while to load workspace and libraries and then stops on checking activation and sits there for 5+min. Sometime it continues, other times it just stops and I have to force quit. I am really hoping this is just a bug and is something that can be fixed. Using Macbook pro 15" Mid2012 2.6ghz core i7 8 gb ram on High Sierra
  3. Thank you for the reply. I have made the adjustments to Display settings and hope that works. Also, thanks for the information about 2016 - 2017. I figured as much but wanted to check. I have had 2017 freeze a lot and crash so I am working in 2016 and 2017. Just wanted to see if I can keep from having to re-create items in 2017 from 2016. Looks like I will build in both until I can get 2017 to be stable. Thanks again!
  4. I upgraded to 2017 and have enjoyed some of the new features but having problems with bugs. Because of 2017 freezing or crashing, I am running both 2016 and 2017. When I try to copy items from 2016 into 2017 they show up as a flat pdf. Is this something new and is there a way around this? Thought it was strange that when copying items from 2016 to 2017 they flatten into a pdf. Also, I am having problems in 2017 where items are disappearing and random center lines and grids are showing up over top of items. I have attache 2 images below. They are from the same diagram and items will just turn off and disappear. If I zoom in or make any changes the items are still missing. I am working on a mac and if I change views to top view, the items show up for a second and then go away. Only way I have found to work around is to change to orthogonal then back to 2d and it seems to work for a bit. Really hope the bugs get worked out quickly so I can work in just 2017 without worrying about freezing, crashing, or items disappearing! gone.pdf Back.pdf
  5. Thanks for all the feedback! Working on large projection screens and video mapping. Just wanted to find a way to do a quick 10 second video with the content playing on the screens and surfaces for sales reasons. Thanks!
  6. You are able to add video elements in Vision? Currently demoing Cinema 4D and it works but takes a long time to render.
  7. I wanted to see if it is possible to use a video file or animate a video file on a screen or object in Vectorworks? I know you can animate a scene with different saved views but I would love to run a video on my screens. I have seen people use Cinema 4D and wanted to see if there was a way to do it in Vectorworks or if there is a better application for adding video files to renders. Please let me know what items you are using to put videos into renders.
  8. I am working on a show file and had my computer freeze when rendering. I have been saving and backing up. When I restored the file from back up, my classes are missing from the navigation field. Everything is there and I can make new classes but nothing shows up in the navigation field for classes. Anyone had this issue?
  9. I just upgraded to 2015 and I am building an LED wall that has a wave to it, I have made 6 2'x2' sections and rotated them to create the screen. Is there anyway to combine the sections and have them display one image? Right now it is putting the image on every tile and not combining. Any advice would be greatly appreciated.
  10. Anybody have any luck finding or creating an LCD podium? Looking for a 40" LCD podium I can display a custom logo on. Tried to rotate an LCD and cannot make it turn to be vertical. Any ideas?
