Christina T
    4
Reputation
0 Neutral
Personal Information
  • Location
    San Francisco
  1. Today I called Tech Support and found out that the Vector Script Plug In Editor is not supported by vectorworks and is a third party feature. Since they could not help, I'm here to ask you all... I changed a bunch of settings for the general plug in objects (like cloud, and reference marker, and drawing label) to auto class to specific classes using our office standard and some settings to set the parameters like handrail extensions etc. After doing this, I created a template file to share with the office assuming that the changes I made would automatically show up in the template but they don't. I don't know much about the organization of VW files on a mac but need to make these changes standard across the board. Can anyone tell me if I've done something really wrong, or if I'm just missing a step and need to replace a library file located on the network? Any advice and help is appreciated. Thanks Christina
  2. Thanks all - I couldn't get the script to work in 12 either. And I know in other programs (like ArchiCAD) it is possibly to check a box to remove wall peaks. I realize that you can create a new plane and fit the walls to that object, but wouldn't it be nice to delete this extra step? VW Tech Support: Any chance you can fix the script so it works in 2012? Mike M Oz & Vincent C- agree about fitting walls to geometry - it should be possible to select a roof and use only that 3D object to fit the walls to.
  3. It would be nice to be able to undo the fit to roof command. I'm sure we're not the only ones who change roof profiles and would like to have a better shortcut than creating a fake roof plane and fitting walls to that roof... Is it possible to undo by typing in a new wall height? Or something along these lines?
  4. I'm fairly new to updating Vectorworks for my office. We have installed 2011 but most projects are still in 2010. I want to update our computers to the latest SP3 before allowing others to start projects in 2011, but wanted to find out if there is a way to keep the service pack from overwriting custom settings? Is there a way, or do I need to just redo it all after the update? Any response would be helpful. Thanks!
