fkfoster
25 -
Everything posted by fkfoster
Compose/Decompose command in the right click options
fkfoster replied to fkfoster's question in Wishlist - Feature and Content Requests
I didn't realize that I could add to the right click menu! My life has been changed! Thanks for the heads up Grant! -
I am having the same problem. It has happen from the start of installing VW 15. We are not upgrading to Yosemite as well due to not supporting current printers. I also noticed just the print dialog box seems to be very slow with this version. I just opened a blank drawing & created 2 sheet layers. I exported to PDF with no problem or lag time. I would say 99% of my files are created from a template made a few versions back. I am think that maybe if I copy all my template info into a new VW 15 file it will solve most of the problems. I am going to do a test on that.
when I try to use the publish command VW is crashing. For example in the publish dialog box I want to print multiple sheet layers. I change from PDF to print in the "Add new item as" drop down menu, VW crashes every time. I like this tool but is getting very frustrating. Also I have noticed that my print dialog boxes are running very slow in VW 15 compared to VW 14. I have change anything on my system. I am not upgrading to Yosemite because it doesn't support any of my printers. Any thoughts?
Compose & decompose in the right click menu
fkfoster posted a question in Wishlist - Feature and Content Requests
I wish that the compose & decompose where an option in the right click menu. -
How to access the print dialog box when publishing?
fkfoster replied to fkfoster's topic in General Discussion
I was hitting the option but not selecting any of the sheets I added to print. That is nothing was happening when I hit the options. Thanks so much Jim! I knew there was away. -
Is there a way to access the print dialog box when using the publish command to print? We use multiple printers from VW & I don't always want to use the last print setting. Thanks!
The first thing I tried was to use the hide edges mode in the polyline edit mode but it doesn't seem to work once the polyline is a ceiling grid object. If I set the line fill to none all my "grid lines" disappear too, not just the ceiling grid edge. I guess I will add this to the wish list. Thanks for your help!
Is there a way to hide the edge of the ceiling grid object in plan? Occasional we show new grid that is an extension of existing grid & I don't want the edge of the ceiling grid to show. My current work around is to covert to a group & delete lines. I would prefer not to have to do that. I have attached a image showing what edges I would like to "hide". Thanks!
I have notices a problem since running the service pack 4. When I edit the design layer through the viewport the little box in the upper right hand corner that lets you return to the viewport is occasionally not showing up. I restart VW & it will work a few times then stop again. This is very annoying since it is the quickest & most used way that I use to return back to the sheet layer. No one else in the office seem to have noticed this going on in their VW.
I have a VW file that I have imported a PDF in to draw over & use as a background in my drawing. When I export to PDF from the VW file the original PDF that is in the VW file appears upside down. This is a fairly new occurrence but has happened on many occasions with different files. If I print to PDF it come out fine. Any one know of a reason that would make this happen? It is just a little annoying.
Keyboard short cut to activate sheet layers
Thanks so much for the help. I knew there had to be one I just couldn't find it anywhere! -
Is there a keyboard short cut to activate sheet layers? I would like to find a quicker way to toggle through all of my sheet layers other than having to go to the navigation pallet & double clicking on the sheet layer. Thanks!
Even with the new service pack 2 I have a lot of crashes while trimming too.
Is there a reason why text styles only show up in the Resource Browser when the drawing is open & not when I am just "browsing a document"?
I occasionally have a problem editing groups in viewports when I am in the annotation mode. It doesn't happen all the time. Usually the only fix is to restart my computer. Has anyone else experienced this?
Multiple text boxes to one
Yes I know! But when you have A LOT to text boxes that you would like to be 1 & you don't want to have to re-type or cut & paste a lot it would be nice to have 1 command to do it all! -
It would be nice to combine multiple text boxed to one text box.
It would be nice to set a class or at least have the option to set the color by class in the Text Style Dialog box!
I am having trouble with the font we use in our office being off-center in all text boxes in VW. It is a font we purchased years ago from Adobe, Graphite Std Font Family. It seams to be fine in all other software. I have talked to Adobe and all they said to do is reinstall it. Didn't work. Any ideas on how to fix it? Thanks!
I have another questions. Is there a way to "subtract" a space inside of the grid to show no grid? My problem: I have a office space where all the walls go to the ceiling but the conference room which is in the middle of the plan. I want a separate grid in this room.
Just learning this tool & need some help. Is there a way to adjust where the grid is inside the polyline of the ceiling grid tool? I want to get rid of the small piece grid it makes. Thanks for the help
